Username Post: Headlights will not work        (Topic#376146)
Wool66
Reg: 12-26-24
12-26-24 03:22 PM - Post#2876563
All lights with exception of the headlights work. Any suggestions?
12-27-24 05:26 AM - Post#2876571
    In response to Wool66
Checked power and ground to the lites? Also, what year and model is the truck.
Wool66
Reg: 12-26-24
12-27-24 10:01 AM - Post#2876580
It is a 1966 Chevy C10
64ss409
Reg: 12-04-02
12-27-24 11:49 AM - Post#2876583
Also check power in and out at the dimmer switch.
Ron
1962 SS convertible, 327/250 4 spd
1956 IH pickup, 327
12-27-24 12:29 PM - Post#2876585
    In response to 64ss409
Yup, common problem area.
Edited by Shepherd on 12-27-24 12:30 PM. Reason for edit: No reason given.
12-28-24 08:10 AM - Post#2876599
make sure you check the bulbs
Woogeroo
Woogeroo
Reg: 05-26-02
01-13-25 01:00 AM - Post#2877025
I had issues with the headlights once, ran around finding shorts here and there. Even behind the fuse panel.
One time it was the dimmer switch on the floor, another time it was the head light switch itself, even though it tested fine, but once you ran power through it, it would not power the headlights anymore. Put a new switch in and it was fine.
Good luck.
-Woog
Execution time: 0.421 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 12:30 AM
