Username Post: 39 Chevy - Chassis Engineering Suspension        (Topic#375939)
AK62
AK62
Loc: Rogers, MN
Reg: 01-23-16
11-03-24 09:02 AM - Post#2875303
I have a '39 Chevy Master 85 and I am considering installing Chassis Engineering's front and rear suspension. Does anyone have any experience they can share?
1971BB427
Loc: Portland,Or
Reg: 12-06-09
11-03-24 09:17 AM - Post#2875304
    In response to AK62
Never installed one, but have seen them on '39 Chevs. My only gripe was the same as others who bought the front crossmember; it's only the crossmember. You still have to buy all the rest of the parts to complete the kit. So expect it will likely end up double the $1000 price for the crossmember once you've purchased the rest, unless you find a donor Pinto or Mustang II to get some parts that can be rebuilt and added to it.
1969 Suburban 2wd 350
1939 Chevy pass. coupe 350/700R4
1937 Austin gasser 327/TH350
11-03-24 10:44 AM - Post#2875310
    In response to AK62
i hope you have good fabrication skills.
AK62
AK62
Loc: Rogers, MN
Reg: 01-23-16
11-03-24 04:50 PM - Post#2875317
    In response to 1971BB427
Everything is expensive these days. Another $1000 doesn't sound too bad!
1971BB427
Loc: Portland,Or
Reg: 12-06-09
11-09-24 08:27 AM - Post#2875441
    In response to bobb
They are a bolt in crossmember, so don't really need fabrication skills. But I would consider maybe some tack welds if I was using it myself.
11-09-24 05:06 PM - Post#2875458
Correct,but make sure the frame is dead square first.
rcr3
Site Ambassador -"20th Year" Gold Supporting Member
rcr3
Loc: MANHEIM PA. U.S.A.
Reg: 11-24-02
11-10-24 05:22 AM - Post#2875461
    In response to AK62
We installed one on my '37 Chevy coupe.It drove great! We put in a few welds,but I loved it!
'67 Camaro survivor
'06 Z71 Sierra Ex Cab
'37 Chevy cp.SOLD!!6/7/14
'73 Nova pro-street project
'17 Chevy Trax LT
1971BB427
Loc: Portland,Or
Reg: 12-06-09
11-10-24 08:04 AM - Post#2875465
It's also a good idea with these frames to tack a brace across the ends of the frame rails once you've determined it's square. Once you remove the stock Master Deluxe crossmember, or remove the straight axle setup things can shift, so a piece of box tubing tacked to the bottom or even bolted to the frame lips will hold it square as you start installation of a MII crossmember system.
11-10-24 11:02 AM - Post#2875467
most everything that is a bolt on needs upgrading. bolt ons are the way they are so most people can do it. i always upgrade.
1971BB427
Loc: Portland,Or
Reg: 12-06-09
11-11-24 10:55 AM - Post#2875486
    In response to bobb
Heck, even Chevy made the Master Deluxe front suspension and crossmember a bolt on from the factory! I think I counted 22 bolts holding the crossmember onto the frame when I removed mine early in my build!
Edited by 1971BB427 on 11-11-24 10:55 AM. Reason for edit: No reason given.
rcr3
rcr3
Reg: 11-24-02
11-12-24 04:03 AM - Post#2875521
Exactly!
'67 Camaro survivor
'17 Chevy Trax LT
Execution time: 0.671 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 09:13 PM
