Username Post: 1965 Chevrolet C10 - heater blower stopped working        (Topic#375929)
Woogeroo
Woogeroo
Reg: 05-26-02
10-30-24 05:45 PM - Post#2875208
1965 Chevrolet C10
Hi folks, so my 3 speed, control on the dash heater blower stopped working after work the other morning. As in, I turned it on, it went off... has not come back on.
When I got home I checked the fuse with a multimeter(ohms) and it tested good out of the fuse panel... checked the voltage across the fuse when I put it back in, still 12v.
Started looking for shorts or a pulled wire, nothing so far.
I guess the motor could have totally gone out at that moment or the switch on the dash which has been in there since I bought it 21 years ago.
Anyway, looking for other things to check, ways to troubleshoot.
Suggestions appreciated. Thanks.
I have the 1963 shop manual and the 1965 supplement as well so I can look stuff up in there too.
-Woogeroo
10-31-24 05:29 AM - Post#2875222
    In response to Woogeroo
Do you have power at the blower and a good ground?
Woogeroo
Woogeroo
Reg: 05-26-02
10-31-24 05:57 PM - Post#2875257
Well, at the wire under the blower motor in the engine compartment it was reading 1.8 volts.
11-03-24 06:10 PM - Post#2875318
If that's the power input, that won't work.
11-05-24 07:32 AM - Post#2875360
so that sounds like it may be the controller, or input to the controller. test it at the controller with the blower on.
Woogeroo
Woogeroo
Reg: 05-26-02
12-06-24 09:25 AM - Post#2876128
    In response to bobb
The wire off of the fuse panel that goes to the switch, when I wire it up to another 12v source, everything runs fine. Weird.
When I test the source on the fuse panel, the fuse is good, the source shows 12v on a multi-meter(on the fuse, outside the panel where the wire slides on, etc.)... and on the wire.
It is the original fuse panel, so could be some damage somewhere, but I am stumped.
*shrug*
Anyway, for now it is wired up to another power source(extra harness) with 12v and is working great.
Thanks for the replies folks.
-Woog
Execution time: 0.686 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 09:34 PM
