Username Post: 65 Chevelle ignition switch cylinder removal        (Topic#375743)
chopr1
chopr1
Loc: Copan, Oklahoma
Reg: 01-11-19
09-22-24 08:15 PM - Post#2874101
The ignition key is stuck in my 1965 Chenille SS. Can the key cylinder be removed without taking out the complete switch. Thank you for any ideas.
larry browning mauldin
Loc: New Braunfels,TX
Reg: 08-16-05
10-21-24 03:58 AM - Post#2874876
    In response to chopr1
If the key is in the switch, you might try to remove the tumbler by finding a small diameter hole in the outer portion of the switch and insert a small drill bit or(even safer) a paper clip. With the paper clip in the hole, turn the key to the left.That should allow the key and tumblers to be removed. Lotsaluck. Larry
10-23-24 08:52 PM - Post#2874966
uh, should be. got pics?
Execution time: 0.674 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 09:31 PM
