Duke
"21th Year" Silver Supporting Member
Loc: Earth (sometimes)
Reg: 04-28-03
09-21-24 07:30 AM - Post#2874053
Question #1
When I turn on my 1955 Chevy headlights, my volt gauge drops and bounces from 14 to 12.5 back and forth when I turn on my parking lights and/or headlights. I replaced my alternator and that did not fix the issue. Chasing the problem now, but I suspect it's the headlight switch or the headlight relay. Anyone else experience this issue or have any suggestions?
Question #2
Thinking about upgrading my old halogen 2D1 headlights to a new LED asseblies, want to increase my visability at night. I like the OEM chrome / clear style headlight look, not the halo with the black bucket look. More watts the better.
Something like this...
https://www.woodyshotrodz.com/HOL-LFRB155-PAIR-p/h...
What original style LED headlight assembly do you recommend?
Tia, Duke
09-21-24 03:08 PM - Post#2874060
In response to Duke
You may have a short in the headlight wiring, causing the circuit breaker in the headlight switch to open and close. Does it do it in high and low beam?
09-22-24 09:15 AM - Post#2874079
In response to Duke
new problem? kindah depends on how your car is wired. do your headlights have big wire upgrades with a relay close by? did you verify voltage with a meter at different points?
Member #409
09-22-24 03:28 PM - Post#2874092
In response to bobb
Stock wiring has no relays.
WagonMan
Loc: Las Vegas, NV
Reg: 10-26-04
09-24-24 03:36 PM - Post#2874160
In response to Duke
You don't say if the headlights go out or just dim when the voltmeter changes.
Do you have an internal or external regulated alternator?
Charles
57 210 4dr. Wagon(bought '82)
-350/700r4 Mild Custom
29 Ford Sedan(bought '75)
-4.3L/TH350(in progress)
Edited by WagonMan on 09-24-24 03:38 PM. Reason for edit: No reason given.
Duke
Reg: 04-28-03
10-02-24 01:19 PM - Post#2874382
In response to WagonMan
I suspect it's the headlight switch. Will report back soon
4dr 57
Loc: Texas Hill Country
Reg: 11-10-04
11-03-24 09:02 AM - Post#2875302
In response to acardon
Do I correctlyremember a small fuse in my original headlight switch?
11-03-24 10:48 AM - Post#2875311
In response to 4dr 57
ive seen those, long time ago.
11-04-24 05:59 AM - Post#2875328
The small 3 amp fuse on 55/56 headlight switche was for the dash lights only. The 2 thermal circuit breakers on the switch protected the rest of the lights.
4dr 57
Reg: 11-10-04
12-01-24 07:55 PM - Post#2876064
Holy Buckets, thanks for that acardon!
