Username Post: Would like a little more exhaust noise        (Topic#375343)
mag
Loc: mpls mn
Reg: 01-04-05
07-16-24 11:38 AM - Post#2871833
My 50th anniversary vette is too quiet. Would like a little more noise without breaking bank, suggestions? Thanks.
grumpyvette
Performance Subject Matter Expert --
grumpyvette
Loc: farmersville texas USA
Reg: 03-16-01
07-16-24 11:25 PM - Post#2871854
    In response to mag
could you be a bit more specific in the type of noise and under what conditions, now that might seem like a silly question, but doing something like removing the muffles while obviously a dumb move is a way to make more noise, a change in the type of muffler , while a bit expensive can also get you a significant increase in noise, but in a much more controlled way, why not talk with a local exhaust shop?
Edited by grumpyvette on 07-16-24 11:26 PM. Reason for edit: No reason given.
wagonmaster
Member #241
Loc: Loganville, Ga.
Reg: 04-28-00
07-17-24 05:30 AM - Post#2871861
    In response to grumpyvette
I used the Corsa muffler on mine. Nice easy rumble until you stand on it then you really hear it! Not cheap but worth the price.
Hey T @!
Joe
Execution time: 0.321 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 01:22 PM
