Username Post: Parallel flow condenser        (Topic#375302)
dgstarr
dgstarr
Loc: Portland, OR
Reg: 04-16-13
07-07-24 04:00 PM - Post#2871565
After converting to R134 I am disappointed in the performance of the AC system. Has anyone converted to a parallel flow condenser? If so, did it improve the cooling?
07-14-24 10:14 AM - Post#2871766
    In response to dgstarr
what are your pressures and temps like?
SSuper Dave
Loc: Pearland TX
Reg: 10-02-05
09-08-24 02:41 PM - Post#2873601
    In response to bobb
A parallel fow condenser will make all the difference in the world, but the POA must be adjusted as well. For a Chevelle, there are a couple of sources for direct replacement condensers, or you can fab one up with a universal piece. I have an exact replacemt on my '70 Elky, 38 at the center vents. I made my opwn for my '68 Caprice, hi 30'son that one as well.
1968 Caprice coupe, 327/275, TH400, Ash Gold/Ivy Gold, Tach Dash, Tilt, Buckets, Console, AM/FM, Rear Defog, Disc and Rallys.
1970 El Camino, 350, TH400, 12 bolt posi, a blank slate!
Execution time: 0.476 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 05:40 PM
