Username Post: photos of 58 Belair with air conditioninginstalled        (Topic#375182)
1958Belairjoe
Loc: FL
Reg: 08-03-23
06-11-24 09:11 AM - Post#2870772
Good day to all ,
Looking to find photos of owners who installed aftermarket air conditioning on there 1958 full size Chevy with the Six cylinder 235 engine .
We are taking on the task now and need some guidance as to what works well on the 235 and what does not work . Mounting brackets ???, generator or alternator or Powermaster gen / alternator , etc .What size ac condenser and so forth . all ideas welcomed on this thanks , Joe
49_Purple
49_Purple
Loc: Krydor, Sask. Canada
Reg: 08-21-15
06-12-24 10:14 AM - Post#2870800
    In response to 1958Belairjoe
Thanks for reaching out to me. What I did to my Impala back in the 80's will give you some idea how to install a/c on your car for a driver not a perfect show car. I used the long GM compressor as seen, made my own brackets to mount it on the 348. Very important to have the belt run straight. The condensor and rec/drier sight glass I took from a late 60's Buick think it was, car had burnt but the a/c stuff was still good so I took it !! The rad you can see is wide but it mounted very well and the lines worked perfect to go through the rad support, and the big plus was that the drier sits where the factory 58 one would have been. Notice how the crossbar that the grill is attached to has a notch in it for the drier. There were 2 types of these crossbars, one with the notch for a/c cars and ones without the notch. But GM had tons of the notched ones so they used them up on non a/c cars too so it is common to see them on any model of 58. The lines I put through the firewall as seen and they go to the uderdash unit. I first had the compressor belt running off the crank and water pump. But twice I took out the bearing on the water pump , no fun changing this on the side of the road 200 miles from home !! So instead I mounted a seperate idler pulley as seen by passing the water pump. Never had a problem since. The stock generator works just fine. Can drive 7 hours with a/c blowing cold with R12 , radio or 8 track playing , lights on, no electrical problems at all with stock setup. Can probably hang a side of beef in the car it gets that cold !! I'm presently building a 58 Sedan Delivery and doing a very similar setup. On the 235 you will have more room to play with mounting the compressor, and probably will go with the smaller ones that are available today in kits
Attachment: IM009676.JPG (644.97 KB) 2 View(s)
Attachment: IM009677.JPG (744.75 KB) 1 View(s)
Attachment: IM009678.JPG (568.76 KB) 1 View(s)
58 Impala Sport Coupe 348 tripower
58 Impala Convertible 348 tripower
58 Sedan Delivery 348
65 Pont Custom Sport
66 Toronado
68 Impala 9 pass wagon original
49 Chev 5window diesel
76 Sierra Classic 454
82 Corvette
84 Corvette
93 Corvette
Edited by 49_Purple on 06-13-24 03:08 PM. Reason for edit: No reason given.
49_Purple
49_Purple
Reg: 08-21-15
06-12-24 10:58 AM - Post#2870804
    In response to 49_Purple
More pics
Attachment: IM009681.JPG (742.37 KB) 3 View(s)
Attachment: IM009683.JPG (754.92 KB) 2 View(s)
Attachment: IM009684.JPG (576.24 KB) 4 View(s)
66 Toronado
82 Corvette
84 Corvette
93 Corvette
49_Purple
49_Purple
Reg: 08-21-15
06-12-24 11:00 AM - Post#2870805
Attachment: IM009685.JPG (704.83 KB) 2 View(s)
Attachment: IM009687.JPG (697.98 KB) 2 View(s)
Attachment: IM009688.JPG (733.03 KB) 1 View(s)
66 Toronado
82 Corvette
84 Corvette
93 Corvette
1958Belairjoe
Loc: FL
Reg: 08-03-23
06-16-24 06:10 PM - Post#2870929
wow , I was hoping to see exactly what you showed me . Looks like you love the oldies just like we do here in Florida . great photos and thanks for the ideas . Funny you mentioned the GENERATOR !! I am keeping stock untill I am proven that it can not work .So much stuff is upgraded for no reason .
Thanks again
1958Belairjoe
Loc: FL
Reg: 08-03-23
06-16-24 06:12 PM - Post#2870930
Love that V8 58 Chevy!!!
49_Purple
49_Purple
Reg: 08-21-15
06-16-24 06:29 PM - Post#2870931
The stock generator works just fine , even idling with the a/c on the GEN light doesn't flicker ( and yes the voltage reg works and bulb is good !! ) . People get a kick out of the ps pump hanging on the back, " what's that thing ? "
66 Toronado
82 Corvette
84 Corvette
93 Corvette
49_Purple
49_Purple
Reg: 08-21-15
06-16-24 06:42 PM - Post#2870933
Here's some of the setup I'm making for the 58 Delivery, not finished yet but hard parts are done. Used a hyd. Hole Punch to get through the rad support , mounted the rad , made mounting bracket for a chrome Sanden style compressor , gotta make lines yet......all takes time when making things to fit.
Attachment: IM008601.JPG (377.18 KB) 3 View(s)
Attachment: IM008595.JPG (434.66 KB) 1 View(s)
Attachment: IM008600.JPG (482.53 KB) 1 View(s)
66 Toronado
82 Corvette
84 Corvette
93 Corvette
Execution time: 0.177 seconds.   Total Queries: 21   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 03:47 AM
