OldRustyWrench52
Loc: So. Florida
Reg: 02-23-20
02-22-24 03:03 PM - Post#2867139
A friend has a bad bearing in the pulley. What is the trick to removing it?
ForeverYoung
![ForeverYoung](https://www.chevytalk.org/fusionbb/images/avatars/10.jpg)
Loc: Orlando, FL
Reg: 05-01-08
02-23-24 02:57 AM - Post#2867151
In response to OldRustyWrench52
You need a puller, similar to a steering wheel puller that bolts to the compressor and pushes on the shaft. Should be able to rent one at a parts store.
fritz1990
![fritz1990](https://i.imgur.com/2ufU5EI.jpg)
Loc: Kansas
Reg: 02-16-03
02-23-24 06:02 PM - Post#2867175
In response to ForeverYoung
What compressor is it?
Regards, Jeff
1998 K1500 6.5 Coal burner
1965 C10 with 498 BBC AFR Heads
1964 C10 Ran 348W for 6 years, now SBC.
Corvettes owned: '74 '77 '78 L82 Silver Anniversary, 2002 LS1, 2007 C6 Love this one! Now have 2014 C7
Don't have a nervous come together!
OldRustyWrench52
Loc: So. Florida
Reg: 02-23-20
03-15-24 07:32 PM - Post#2867987
Typical steering wheel puller not large enough to span the 6"+ compressor pulley. Had to fabricate my own, but got it done.
OldRustyWrench52
Loc: So. Florida
Reg: 02-23-20
03-15-24 07:34 PM - Post#2867988
In response to fritz1990
How many different compressors were available for the stock '57?
