Username Post: Compression test without intake manifold        (Topic#374122)
Dans55
Reg: 03-03-22
12-03-23 05:54 PM - Post#2864717
I want to do a compression test after I put my cylinder head back on. Is it necessary to have the intake manifold installed? I have a oil printer rod that I used at one time with a drill. I plan on running the pump around 5 minutes before I do the test.then another 5 minutes before I do the second head. Think that will work?
Don57
Don57
Loc: Illinois
Reg: 04-28-00
12-03-23 06:35 PM - Post#2864719
    In response to Dans55
I've never done it but I think it will work, as long as the valves are operational.
1957 3200 Stepside
12-04-23 08:09 AM - Post#2864724
compression test will work need the correct tool for oil prime
12-04-23 08:56 AM - Post#2864725
    In response to bobb
Yes you can do a compression test like that, as mentioned. But, 5 minutes priming is unnessary, maybe 2 minutes after pressure is achieved. Important to turn the engine 180 from tdc to get to all bearings.
OldRustyWrench52
Loc: So. Florida
Reg: 02-23-20
04-08-24 04:35 PM - Post#2868712
Edited by OldRustyWrench52 on 04-08-24 04:39 PM. Reason for edit: No reason given.
OldRustyWrench52
Loc: So. Florida
Reg: 02-23-20
04-08-24 04:38 PM - Post#2868713
How about using a piece of pvc pipe as a spacer that would closely duplicate the intake manifold's thickness and hole diameter? Then the distributor would run the oil pump while doing the compression test. You may need something to run the length of the block to support the piece of pvc.
Execution time: 1.519 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 01:56 AM
