Username Post: Suggestions on installing cylinder head        (Topic#374044)
Dans55
Reg: 03-03-22
11-20-23 04:16 PM - Post#2864308
I had a heck of time lifting that cast iron head off the engine. I can only imagine how difficult it will be lifting it and placing on the engine without damaging the head gasket. Any suggestions besides Hulk Hogan.
11-21-23 06:27 AM - Post#2864320
    In response to Dans55
Put some long studs in a couple of the head bolt holes to guide the head in place and either get some help or use a engine lift.
11-23-23 10:34 AM - Post#2864414
when doing heavy awkward jobs like that, i sometimes put wood strips down to protect the surface. then i do the alignment and remove the strips.
55MAS
Loc: North Coast, USA
Reg: 12-19-01
11-24-23 06:31 AM - Post#2864447
    In response to bobb
The factory hollow dowels provide all the alignment needed. Long studs and other just complicate installation. The real issue is OP cannot lift alone. As suggested above get a helper or two and a beer or two for the helper(s), or get out the checkbook or credit card. It may even be an issue to provide the necessary torque to the head bolts depending on OP's actual situation.
Execution time: 0.498 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 01:01 AM
