Dans55
Reg: 03-03-22
11-04-23 02:02 PM - Post#2863864
On my 1970 chevy 350 engine, stock heads,what is the thickness of gasket should I use and brand name. Only replacing the gasket for one cylinder head.
11-04-23 03:31 PM - Post#2863865
In response to Dans55
Assuming it's stock from day one, an oe replacement FelPro will do the job.
55MAS
Loc: North Coast, USA
Reg: 12-19-01
11-05-23 07:02 AM - Post#2863875
Why can't you measure the old one that was removed? Certainly can identify the gasket type and perhaps a PN. Or you may be able to use a shim gage on the other head to measure the COMPRESSED thickness.
Barring the above replace them both with a set. Generally the gaskets come in pairs.
Dans55
Reg: 03-03-22
11-05-23 09:57 AM - Post#2863880
In response to 55MAS
Didn't realize they had numbers on them. I'll check on that.
11-06-23 08:41 AM - Post#2863892
you need to measure the piston to deck height. you probly have the wrong gasket on there.
