Username Post: trans filter        (Topic#373772)
J C
Loc: Orange Co. Calif
Reg: 04-17-04
09-16-23 02:57 PM - Post#2862596
After driving this car about 10 miles I checked the trans filter (th350). It was full but mud brown.Pulled the pan and things got worse. Looked like sand at the bottom. Trans seemed to work ok. Changed filter and 4 qts oil. Drove approx 5 miles check fluid mud brown again. Pulled pan had a little crap in bottom but still mud brown. New filter & oil again. I know this is going to take numerous times to get the mud fluid color out. Is there a way to short cut this. I know the torque converter is loaded with this brown oil.
69RSZ28 71 Chevelle 79 Silverado 24K mi.
docjns1
docjns1
Loc: upstate NY
Reg: 11-12-19
10-17-24 02:43 PM - Post#2874788
    In response to J C
If you've not gotten it cleaned out part of me would suggest a power flush but then part of me says that might do (more?) harm. if its driving/shifting fine I'd probably check the radiator/cooler and flush that separately. You can buy aerosol cooler flush at most parts outlets. They'll usually come with a hose fitting to connect to your lines or cooler fitting.
Steve
327 / 300 L74
M11 3 on the tree
12 bolt 3.31 open dif
10-17-24 04:04 PM - Post#2874791
    In response to J C
Lot of that stuff is in the convertor and cooler as mentioned, might take 3 changes to get most of it out, but something is going in the trans to cause that.
Edited by Shepherd on 10-18-24 06:29 AM. Reason for edit: No reason given.
10-19-24 09:55 AM - Post#2874838
agreed. something aint right in there.
J C
Reg: 04-17-04
10-19-24 06:06 PM - Post#2874850
    In response to bobb
Thanks for all the replies. I just took this car back from my two sons because they kept complaining that their friends have newer cars. Took it back and said " go buy whatever you want and can afford. The car sat for a couple years before I started to correct things so I have no Idea what was or wasn't done to the car when they had it. Just before I started to restore the car both boys asked what I was going to do with the Chevelle. I said you are not getting it back. They finally realized what they gave up.
elcamino
Member #185
elcamino
Reg: 03-30-00
02-15-25 10:51 AM - Post#2877888
    In response to J C
Might be better off in the long run to just replace the trans and TC than to keep trying to save this one.
2024 GMC 4WD Sierra Denali 3.0L/10-sp
2022 Polaris RZR XP 1000 Ride Command
2017 John Deere X738
Execution time: 0.617 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 12:44 AM
