Username Post: Steering Wheel 1957 B.A. or 210        (Topic#369325)
elvis
elvis
Loc: Ontario
Reg: 11-10-05
08-28-22 06:50 PM - Post#2846473
Hi everyone,
What is the structure of a steering wheel for a tri-five? I realize there is a steel center hub and steel running through the spokes and rim (the skeleton). How is it held together? eg. Is it welded or cast as one piece of metal before the resin coating is applied?
Pouring money between the wheels.
Original57
Loc: Houston, TX
Reg: 04-07-09
11-01-22 05:42 PM - Post#2849409
    In response to elvis
the original 57 st. wh. has a steel circle, not sure about the 2 spokes to the center hub. I had to partially rebuild mine using a epoxy resin kit. I did a small section at a time, because I had to use a set of hand files to re-shape the new epoxy to match the original grooves and indentions. This took a lot of time. If a modern, reproduction of the original st. wh. is available, I would recommend to buy it instead of remanufacturing.
58 Biscayne
58 Biscayne
Loc: Kansas City MO
Reg: 02-26-10
09-21-23 01:54 PM - Post#2862727
    In response to Original57
Older post I know, but personally I would reman your original wheel. I went with a reproduction wheel from Ecklers on my '57 and it has flex, noticeable flex. Glad I kept the original GM wheel, just hadn't gotten around to restoring it with epoxy yet. If I did it again I would restore your original wheel if you have enough of it to do.
Robert
1931 Chevrolet, traditional hotrod
1956 4dr 210 post
1956 4dr Belair post
1957 4dr Belair post
1958 4dr Biscayne w/ Belai
Execution time: 1.024 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 09:21 PM
