Username Post: Axle bearings        (Topic#368499)
Deuce_Coupe
Deuce_Coupe
Loc: Mankato, MN
Reg: 09-18-01
05-23-22 04:02 PM - Post#2841694
Two questions.
#1 Can the "lock ring" on the backside of the bearing be reused? I thought I read someplace that they should be replaced when replacing the bearings.
#2 Does it matter which way the bearings are installed? Right now the O-ring is on the outside and I'm wondering if I can put the O-ring to the inside. The housing has a better surface on the inside for the O-ring.
Sealed bearings 1956 Chevy.
32 5W Coupe
53 Bel-Air 2dr sedan
64 Chevelle Convert
65 Impala 2dr HT
78,87 Silverado K20
86,87,90,91 Suburbans
Joeyd59
Joeyd59
Loc: New Jersey
Reg: 02-11-12
05-24-22 04:07 PM - Post#2841747
    In response to Deuce_Coupe
No sir,the lock ring cannot be reused once you remove it.Hence why when you purchase the axle bearings a new lock ring comes with it.The O Ring faces to the outside.The actual seal is on the inside.Clean the flange and make sure it isn't bent and DON'T forget to put in on before you install the new bearing.You press the bearing and lock ring on together.Make sure the axle tube is clean and smooth and don't try walking the axle in with the flange as you can bend them easily.Lubricate the new bearing and slip the axle in.You can use RTV in the mounting flange side.These axle bearings have been through several changes since 1955.Original 55 axle bearings stand alone as well as the axle flange plate.GM issued a TSB in early 56 for replacement of 55 axle bearings utilizing the current production axle bearings which GM used through 57 which used 1 O Ring.In 58,they were changed again and now have 2 O Rings and were used up to 64.The oil seal is part of the bearing.Original bearings were NDH.I use Timken in my shop exclusively if I can get them.
hd_cat
Reg: 02-13-24
02-14-24 09:21 AM - Post#2866890
    In response to Joeyd59
Agree with your comments and recommendations for the bearing removal and replacement. My concern is that there is no real physical barrier to the bearing working its way out laterally. The end cap/dust cover I.D. is larger than the bearing O.D. and for that reason the bearing could walk and cause damage to the tire, fender, and possibly the carrier if the axle moved far enough to disengage the splines. I am helping a friend with his '55 Wagon and we're working on a solution, hope someone else has an idea to solve this issue.
03-05-24 07:46 AM - Post#2867565
    In response to hd_cat
What? Why is the "retainer" trapped on the axle if the bearing would pass through it and why is it called a retainer? https://lh3.googleusercontent.com/proxy/Ul1ZIW-ozx...
Execution time: 1.927 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 12:01 AM
