Username Post: Turn signal problem on 1988 Chevy C1500        (Topic#79196)
Keith P
Reg: 10-27-04
10-27-04 11:08 AM - Post#539963
Hello!
The turn signals have stopped working on my 1988 Chevy C1500. The four way flashers work fine. All fuses are fine (checked them all). Both flashers replaced already and that wasn't it. I plugged in a new turn signal switch at column and that didn't work either. Could this be ignition switch related? Or does anyone have any other ideas? I'm grasping...
88k1500inAZ
Loc: Northern AZ
Reg: 10-28-04
Re: Turn signal problem on 1988 Chevy C1500
10-28-04 08:59 AM - Post#539964
    In response to Keith P
KeithP
I own a 88 k1500, and I have the same problem, I found that the flasher block on the firewall was loose, I put a wedge to make it tight but it stil needs tightned down, I am not sure how to get behind the board, and resolder, or what?
I am also not sure if it is the same on a k, or a c model?
Hope this helped.
Clint
I own a 1988 Chevrolet K1500 4.3l 4 Speed Manual Cheyenne and I love it!!!
Phazer
Phazer
Loc: Armpit of the Universe
Reg: 10-10-03
10-28-04 12:34 PM - Post#539965
The flashers used in those had a tendency to gradually start sagging over time. Maybe the contacts got hot and melted in the block. Get a flashlight and look them over real good.
good.wrench
Chevytalk Staff
good.wrench
Loc: new york,usa
Reg: 03-30-01
10-28-04 12:41 PM - Post#539966
it could be ignition switch related,the t/signals do not get any current until the key is on,then there should be current at the t/s flasher.
good.wrench
c/t staff
84 S-1O 4x4 if your poor your crazy,if your rich your eccentric!
Wack
Loc: Cincinnati
Reg: 08-09-04
10-29-04 07:53 AM - Post#539967
Does your truck have tilt steering and do you use the tilt often. I have found when you use the tilt frequently over time the wires break inside the steering colum. You said you replaced the turn signal handle but did you replace the wireing harrness that runs through the steering colum for the turn signal switch.
88k1500inAZ
Loc: Northern AZ
Reg: 10-28-04
10-30-04 02:58 PM - Post#539968
    In response to Wack
I am still having this problem also.
A question though, does the flasher "unplug" from the board?
I felt alot of resistance when I tried to unplug mine, I did not want to break it, so I tried the poor man way to fix it?
Clint
Phazer
Phazer
Reg: 10-10-03
10-31-04 03:05 AM - Post#539969
    In response to 88k1500inAZ
Yes, it should pull straight out toward the seat.
88k1500inAZ
Loc: Northern AZ
Reg: 10-28-04
11-05-04 08:44 AM - Post#539970
    In response to Phazer
Thanks Phazer
It pulled straight out, found some corroision, clead it off, will try it when I drive home, worked on it during my lunch hour.
If I have to replace shoud I go heave duty if I never tow anything?
Clint
88k1500inAZ
Loc: Northern AZ
Reg: 10-28-04
11-05-04 04:01 PM - Post#539971
My turn signals worked great.
Thanks again
Clint
Execution time: 0.265 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 07:45 PM
