Username Post: '89 4x4, 27spline to 32 spline output shaft        (Topic#70678)
StarCraft
Loc: Good 'Ol US of A
Reg: 09-23-02
07-13-04 01:34 PM - Post#479686
During my truck rebuild, I'm wanting to convert the current 5 speed transmission to a 700R4 automatic. I've already got the transmission, but after some last minute information, come to find out that the output shaft is 27 spline. My existing transfer case is a 32 spline input. Now what do I do? Can I change just the input shaft on the transfer case? If so does anyone know the part number of the shaft? What is involved in changing it? My transfer case is an NP241C.
OR - Is there an adaptor shaft? I also have an NP207C transfer case from an S10 Blazer laying around with 27 spline input shaft, can I use that shaft in my 241C?
Here I am with money invested in a tranny, and in a new trans to transfer case adaptor(from GM) and I'm stuck with not being able to mate these things up. All because I listened to someone tell me it will work.
Can anyone help PLEASE? Thanks in advance.
Jim C. 1985 S10 Blazer 2WD 350,TH350 1989 2500 4x4 Ext. Cab 1994 Sunbird 'vert w/3400 2002 Malibu
Jay727
Old as Dirt Member
Reg: 09-02-01
Re: '89 4x4, 27spline to 32 spline output shaft
07-13-04 01:53 PM - Post#479687
    In response to StarCraft
Are you sure on the numbers of each t case? S-10 blazers come with 241C t cases.
Almost every one of them had a 700R4 in front of it so the parts should not be hard to find.
It might be easier and cheaper to just get a used transfer case.
FWIW if you don't already know a 241C came out of a chevy, a 241J came out of a jeep and a 241AMC came out of an AMC.
Only the Chevy has a 27 spline input.
StarCraft
Reg: 09-23-02
07-13-04 03:05 PM - Post#479688
    In response to Jay727
Well, If these numbers are wrong, GM really F@#%$D up and mismarked the tags on these transfer cases. I'm willing to bet GM marked them right, and I'm reading them right.
As for being easier and cheaper to find another transfer case....EXACTLY what year and model full size truck do I need to find the transfer case from?
Anonymous
07-13-04 04:39 PM - Post#479689
The numbers are probably right, big blazers came with 208 or 241 transfer cases, the s series had the 207 style. You actually don't need a shaft, the input to the transfer case is a gear with an internal spline to fit the transmission shaft, you can remove your present gear and install one with the correct spline count in it's place but it will require disassembling the transfer case, the 241 case is a better case than the earlier 208, but the aluminum cases are prone to cracking on both, I would think you could find that input gear from a junk 241 case without much trouble, they used that case well up into the mid-90's.
Jay727
Old as Dirt Member
Reg: 09-02-01
07-13-04 11:48 PM - Post#479690
    In response to
OK I was thinking of the NP231C sorry to ruin your day.
All S-series came with 231 transfer cases.
241C came in '88-'93 full sized.
StarCraft
Reg: 09-23-02
07-14-04 01:48 PM - Post#479691
    In response to
95_Silverado, so what you're saying, I can't take the 27 spline input gear out of my S-Series 207C transfer case and put it into my 241C transfer case? Do I need to find a 241C transfer case with a 27 spline input gear?
Thing is, I called the dealer about a 27spline input for my transfer case, '88-90 that I asked about all had the same part number, regardless of whether it was 1/2 ton or 3/4 ton, or if it was automatic or stick, did'nt make a difference. The dealer did'nt show a spline listing, he just said they were the same number. Thanks,
wkobe
Reg: 02-04-04
07-14-04 01:57 PM - Post#479692
alittle quick research i found this web page it will show you all the t-case available
http://www.drivetrain.com/transfercaseapp.html#Chevrolet%20K%20Series%201500
wayne
1996 k1500 4.3 276k miles
1996 k2500 5.7 118k miles
1998 k2500 5.7 115k miles
StarCraft
Reg: 09-23-02
07-19-04 03:54 PM - Post#479693
    In response to wkobe
I've already seen that site. It was a little help, but not complete. Anyone know what the GM part number is for a 27 spline input gear for a 241C? Or if the 207C input gear will work in my 241C?
That site was a bit vague.
Thanks,
Jay727
Old as Dirt Member
Reg: 09-02-01
07-19-04 04:05 PM - Post#479694
The 241 and 207 inputs don't interchange.
Call drivetrain direct they are very helpful.
Personally I'd just get a t case from a junkyard amd either use it or swap out the input.
Execution time: 0.224 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 09:07 AM
