Username Post: 1970 Short Step C10 on 1978 K5 Blazer 4x4 Chassis?        (Topic#54424)
1964SS
Reg: 09-30-01
01-08-04 05:51 AM - Post#369181
I just picked up a 78 K5 Blazer 4x4 with a new motor, tranny. transfer case, and a 2" lift kit. I bought it as a motor/tranny donor for one of my projects, but I'm thinking about utilizing some of the other parts.
Would a 1970 C10 Shortbed Stepside body fit the blazer chassis well?
Thanks!
Mudder67
Loc: East central Missouri
Reg: 01-01-04
Re: 1970 Short Step C10 on 1978 K5 Blazer 4x4 Chassis?
01-08-04 06:22 AM - Post#369182
    In response to 1964SS
Blazer chassis are shorter than your C10. You can make it work out good but it would probably be best to lengthen the Blazer Chassis. I used a 77 chassis and had to shorten it a tad for my 67 stepside.
67 Chevy Stepside 4x4
JimKshortstep4x4
Chevytalk Moderator & "14th Year" Silver Supporting Member
JimKshortstep4x4
Loc: Muskegon, MI, USA
01-08-04 06:52 AM - Post#369183
Blazer frame is 6" shorter than short bed, (109" WB for Blazer, 115" WB for shortbox).
66 Impala SS, 396, TH 400
69 El Camino, 350, TH 350
1964SS
Reg: 09-30-01
01-12-04 02:38 PM - Post#369184
ok thanks.. What would it take to swap the drivetrain & suspension out of the 78 blazer 4x4 into the 70 c10 shortbed?
mr wabbit
mr wabbit
Loc: IL
Reg: 02-26-02
01-14-04 07:48 AM - Post#369185
it would take alot of rivet cutting and frame rail hole drilling and measuring, its not fun, you would also need to swap all the body mount frame brackets over, including rad support ones and everything from the blazer chassis, you will be better off just finding a 72-older 4x4 chassis, the wheelbases changed n 73, everything got lengthened almost half a foot in 73, blazers included.
good luck
Randy
Lincoln Il
1982 Trans Am WS7
305 TH350 7.5" for now
http://smg.photobucket.com/albums/v298/fast68/ra nd...
1964SS
Reg: 09-30-01
01-16-04 04:55 AM - Post#369186
    In response to mr wabbit
What I meant in my second post was can the 78 blazer 4x4 front crossmember/suspension/engine/tran/transer case be installed on the 70 c10 frame?
I also have a 66 c10 with a 71 c1o front crossmember and suspension and the swap was a piece of cake (2WD)
Thanks again. Chevytalk rules.
Execution time: 0.441 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 05:07 AM
