Username Post: How were spark plug wires run on 265 V8        (Topic#52346)
tdsoup
Loc: Petaluma, CA
Reg: 03-24-01
12-13-03 08:19 PM - Post#354384
I am looking to replace the spark plug wires on an original 265 V8. Right now they are just coming off the top of the distributor and run wherevere. Was there a stock wire routing. If so does anyone have a picture to share?
Thanks,
Todd
56 Bel Air Hard Top with 2x4 carb 55 Nomad to be restored :-)
50sChevys
50sChevys
Loc: Central Texas
Reg: 03-23-02
Re: How were spark plug wires run on 265 V8
12-14-03 02:03 AM - Post#354385
    In response to tdsoup
Here you go, Todd..
Plug Wire Routing
50s Chevys
Anonymous
12-14-03 04:29 AM - Post#354386
What the assembly manual photo posted previously fails to stipulate is there are small wire "locators" bolted to the engine block with a small screw.
Each locator retains the wire to the side of the block with a grommet.
If you need the correct spark plug wires I would recommend.... www.factoryfit.com
GaryC
GaryC
Loc: Pittsburgh, PA. U.S.A
Reg: 02-28-03
12-14-03 04:44 AM - Post#354387
    In response to 50sChevys
Was there a wire loom on the pass. side as well? I like the look of those and thought I'd get a set on this year.
Gary
1957 Chevrolet Bel Air coupe, 300hp 327, M20 4 speed
50sChevys
50sChevys
Loc: Central Texas
Reg: 03-23-02
12-14-03 05:42 AM - Post#354388
    In response to GaryC
Yes, there is a loom on the passenger side at the rear of the block.
50s Chevys
Robert_May
Old as Dirt Member
Loc: San Marcos, CA USA
Reg: 01-03-02
12-14-03 08:56 AM - Post#354389
That drawing of the engine is rather crude but it does show the looms at the top of the engine and underneath at the back of the block well.
I'm not sure exactly what the 265 had for the rest of the loom but what isn't shown is the arc shaped loom piece for the two front wires that all of the other engines (and I suspect the 265 also) had.
The passenger side is a mirror image of the driver's side.
I suspect that Chevy used the same parts for the loom for a long time and there is probably plenty of them floating about. when the side mounts came along, the arc shaped pieces got a notch for the side engine mount.
Robert May Fat? Eat less and you will get thinner!
Robert_May
Old as Dirt Member
Reg: 01-03-02
12-14-03 08:56 AM - Post#354390
Anonymous
12-14-03 09:55 AM - Post#354391
Here's a little more comprehensive view of all the wire looms on a 55-56 265:
http://www.55-57chevys.com/coccc/tech/55/221-11.gif
cdmhenry
Loc: Minden, NV.
Reg: 09-14-00
12-14-03 10:53 AM - Post#354392
    In response to Robert_May
Robert,
There weren't wire "bananas" on the ordinary 265 as there were on the '57+ 283 engines. The "bananas" were heat shields made necessary by the change to "rams horn" exhaust manifolds.
Every Government Interference In The Economy Consists Of Giving Unearned Benefit, Extorted By Force, To Some People At The Expense Of Others - Ayn Rand
Robert_May
Old as Dirt Member
Reg: 01-03-02
12-15-03 09:18 AM - Post#354393
    In response to cdmhenry
The bananas were used for a lot of manifolds. I've got a '66/7 283 in my '52 and it has the log manifolds (passages drop down and together) with heat shields over the manifold at the plug areas and I've got the bananas on it. It was a bit of a nasty when I put solid wires on the engine as it was hard to thread the larger wires through those slots.
BayouBob
Loc: Ruston, LA USA - Native T...
Reg: 03-05-02
12-17-03 08:56 AM - Post#354394
    In response to
Hey BTO, Where the spark plug connectors slanted at about 45 degrees instead of 90 degrees? Were the connectors and wire all black?
1955 Bel Air 4-Door 6 years to complete!
Anonymous
12-18-03 01:56 AM - Post#354395
    In response to BayouBob
Actually the early 55 design was slightly tighter than a 90 degree bend. The 56 and later were a true 90.
Boots and wires were black - and there is no "date code" on a '55 wire.
BayouBob
Reg: 03-05-02
12-18-03 08:20 AM - Post#354396
    In response to
Thanks BowTieOllie. I knew you would have the answer!!
55nomad
55nomad
Loc: San Antonio, Tx
Reg: 12-27-02
12-18-03 11:56 AM - Post#354397
Are the brackets painted black or do they match the engine color?
Tom
Anonymous
12-18-03 01:01 PM - Post#354398
    In response to 55nomad
Yes .
The two four-wire brackets at the top of the engine (the ones that the wires first go into on each side) are engine color. All the others are semi-gloss black.
tdsoup
Loc: Petaluma, CA
Reg: 03-24-01
12-19-03 08:09 AM - Post#354399
    In response to
Are the brackets both the manifold and engine versions available? Or are there alternatgives to consider
Anonymous
12-19-03 08:39 AM - Post#354400
?? Not sure what you're asking, but if you want to know if all the original style looms are being reproduced, yes, there is a repro set available. It is not as accurate a repro as I would like, but it'll do if you don't have anything. Comes with all the rubber stuff too.
Execution time: 0.353 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 04:01 PM
