Username Post: Muncie vs Doug Nash/Richmond 5 speed Transmissions        (Topic#49657)
Vern's_57
Vern's_57
Loc: Hamburg N.Y. USA
Reg: 04-11-02
11-12-03 02:21 AM - Post#334997
I'm thinking about replacing the transmission in my 57.I have a muncie 4 speed in it now and I was wondering if any of you guys ever put a Doug Nash/Richmond 5 speed trans in your cars ? my concern is the space around the trans tunnel. Will the shifter linkage clear the floor without taking a hammer to the tunnel and will the shifter come up through the same hole ?? Positive / negitive feedback on those 2 trannys
Chevy_Muscle
Chevy_Muscle
Loc: Murphy(Dallas), TX
Reg: 02-04-02
Re: Muncie vs Doug Nash/Richmond 5 speed Transmissions
11-12-03 02:33 AM - Post#334998
    In response to Vern's_57
I think "fiftysixbowtie" has done this recently.
Try a search on this screen name and you should find lots of info on this.
... or maybe he was running another 5-speed.
........ Anyway, there is lots of info on 5-spds and 6-spds in the last 6-months so a search should give you great results
....At no point in your rambling, incoherent response were you even close to anything that could be considered a rational thought. Everyone in this room is now dumber for having listened to it.
ZZ430
ZZ430
Loc: Missouri City, TX, USA
Reg: 05-31-02
11-12-03 04:06 AM - Post#334999
I've got a Richmond 6-speed. No hammering required.
5-speed should be the same.
http://www.cardomain.com/ride/208734
awsum55
awsum55
Loc: O.P. Kansas
Reg: 09-27-01
11-12-03 06:01 AM - Post#335000
I have the Richmond 5 speed and as mentioned no mods needed. You will have to buy a special shifter for it (about $300). You will also have a big difference in your first gear so it might require you to change the gears in your rear. I had to go with a 3.25 gearset because 1st gear is so low you'll be able to pull stumps. I started with a 3.73 and it was so low, I could chirp the tires in 5th gear and 1st gear would red line in about 30 feet.
Five things that you cannot recover in life:
* The Stone after it's thrown
* The Word after it's said
* An Occasion after it's missed
* The Time after it's gone
* A person after they die
Vern's_57
Vern's_57
Reg: 04-11-02
11-12-03 06:31 AM - Post#335001
    In response to awsum55
I have a 12 bolt with 3:55, you also mentioned a special shifter ?
No_Dice
"13 Year" Silver Supporting Member
No_Dice
Loc: San Jose, CA
Reg: 04-23-01
11-12-03 06:51 AM - Post#335002
I have a the Richmond 6 and it really is my favorite part of the car. No tunnel mods as mentioned above. Richmond was a good company to deal with after the sale. Look into the T-56 also....lots of folks running those. Must be a good reason.
BOB_SPRADLIN
BOB_SPRADLIN
Loc: Saginaw, Michigan USA
Reg: 04-08-02
11-12-03 09:03 AM - Post#335003
Vern,
The Richmond 5-speed is not a overdrive trans. if thats what your looking for, its 1 to 1 final drive. Good Luck.
Bob
Vern's_57
Vern's_57
Reg: 04-11-02
11-12-03 12:34 PM - Post#335004
    In response to ZZ430
ZZ430, Does your shifter come up through the left side of the tunnel where my muncie would go through, and is The 6 spd the same as the 5 spd but with overdrive ?
Danscool57
Loc: Rockford, MI 49341 USA
Reg: 11-14-02
11-12-03 01:19 PM - Post#335005
Just thought I'd add my 2 cents (more info). I have a new Richmond 5-speed and because of the gear ratios, I'm running a 3.08 posi unit behind it (as per advice from Richmond). I, also, think they are good to work with (good tech support). I called around for a shifter. I wanted one that wrapped around my bench seat and Longs was the only one that offered it (pricey at $400.00).
'57 210 2dr. Sedan, 355, 5-speed, 3.08 Posi 12-bolt, custom paint, Bel-Aire sedan interior, front disc's, air.
No_Dice
No_Dice
Loc: San Jose, CA
Reg: 04-23-01
11-12-03 01:25 PM - Post#335006
    In response to Danscool57
Dan - I got the 6 speed for the overdrive but at $2900 the shifter was included. I'm running a 3.0:1 rear gear. I had many converstaions with Dean in Tech Support. One of the only companies to actually call you back if you left a voice message. American Autowire was very good on that also.
ZZ430
ZZ430
Reg: 05-31-02
11-12-03 05:46 PM - Post#335007
Vern's_57
Sorry it took awhile to respond but I had to take my son to hockey practice. The shifter comes up through the floor where a bench seat would go. It comes up to the left of center but back a few inches. Yes, the 6-speed is the same as the 5-speed with an added overdrive gear.
Vern's_57
Vern's_57
Reg: 04-11-02
11-13-03 02:28 AM - Post#335008
Thanks for all of the info, Vern
Execution time: 0.198 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 07:26 AM
