Username Post: Vintage Medal Fuse Box?        (Topic#43097)
spdmrcht
Reg: 05-25-03
08-25-03 06:15 PM - Post#289103
I came a cross a red medal round top fuse box
that has large black letters saying. ANTHES
TRUKFLAR then UL with a circle around it. Does
any have any Info. about this? Thanks.
Royer
Needs to Get Out More Member
Loc: Bloomfield Hills, Michiga...
Reg: 09-25-01
Re: Vintage Medal Fuse Box?
08-26-03 02:01 AM - Post#289104
    In response to spdmrcht
I believe that what you have found is a package of flares that were intended to be carried by trucks over 10,000 lb GVWR (ones whose operation was regulated by the Interstate Commerce Commission). These were, I believe, intended to be lit and placed behind a disabled truck at the side of the road - to warn oncoming drivers of its' presence.
I'm unsure of the vintage, but would guess at anywhere between just before ww2 up to the early 1960s.
Does this make any sense judging from whatever you can read on the packaging?
TooMany2count
Old as Dirt Member
Loc: Cahokia, IL
Reg: 12-12-01
08-26-03 06:46 AM - Post#289105
http://www.motionunlimitedmuseum.com/oneitem.php?itemid=151
here you go, this is the only thing I found on it...........joe
Donate Blood, Plasma, Platelets & Sign Your DONORS CARD.
The Life You SAVE Might Be Someone You Know and LOVE.
Two possibilities exist:
Either we are alone in the Universe or we are not.
Both are equally terrifying.
Arthur C. Clarke
Royer
Reg: 09-25-01
08-27-03 01:12 AM - Post#289106
    In response to TooMany2count
This is exactly what I had in mind when I wrote my previous post. The photos and text clearly confirm what I'd suspected.
Execution time: 2.76 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 02:27 PM
