Username Post: SBC timing gear and chain install        (Topic#276023)
dc_motruck
Loc: Rural Missouri
Reg: 02-01-10
02-06-12 11:52 AM - Post#2187815
I need some expert info to settle a debate. When installing a new timing gear & chain on a small block chevy (a 1988 5.7 TBI) where are the dots on the gears supposed to be when #1 cylinder is at TDC on compression stroke?
What would be out of whack if #1 was TDC on compression and the dots were lined up with each other (crank gear dot at 12 oclock and cam gear dot at 6 oclock) ?
aghaga
aghaga
Loc: Altavista, Va.
Reg: 07-05-08
02-06-12 12:21 PM - Post#2187819
    In response to dc_motruck
#1 on comression will be with both the crank dot and the cam dot @ 12 o-clock. With the crank dot @ 6 o-clock cyls. 4&7 will be on TDC.
62chevy427
62chevy427
Loc: laurens sc
Reg: 04-13-06
02-06-12 12:24 PM - Post#2187820
the dots should be - crankshaft at 12 oclock and camshaft at 6 oclock. when installing distributor with this set up,the rotor should be ready to fire on #6. never did like that. it has caused me lots of confusion until i figured it out. now,after installing a timing chain and gears,after turning the engine at least 2 turns to verify a correct installation,i leave it with the crank and the cam at 12 oclock. that way i can install the distributor to fire #1 cylinder. i install it so that the rotor is just past the #1 post on the distributor cap.squirt some gas into the carb and it will crank up right away. then set timing etc.
56 bel air ((since 2002)
62 impala ss (since 1965)
65 el camino (since 1969)
66 nova (since 1987)
83 gmc 4wd (since 1991)
95 impala (new)
14 camaro (new)
grumpyvette
grumpyvette
Loc: FLORIDA USA
Reg: 03-16-01
02-06-12 01:00 PM - Post#2187832
    In response to 62chevy427
Edited by grumpyvette on 02-06-12 01:02 PM. Reason for edit: No reason given.
dc_motruck
Loc: Rural Missouri
Reg: 02-01-10
02-06-12 02:37 PM - Post#2187866
    In response to grumpyvette
Thanks. That's where the confusion was... what cylinder was at compression when the dots were facing each other (12 & 6 oclock).
MikeB
MikeB
Loc: Plano, TX
Reg: 08-28-03
02-08-12 12:01 PM - Post#2188535
#6 is at TDC compression when dots are next to each other.
Edited by MikeB on 02-08-12 12:03 PM. Reason for edit: No reason given.
Execution time: 5.813 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 01:26 AM
