Username Post: 59 Powerglide overhaul        (Topic#272829)
Vic
Vic
Loc: Yass, NSW, Australia
Reg: 09-20-11
11-29-11 07:26 PM - Post#2163310
With the factory manuals winging their way to me, I am preparing to overhaul my 1959 powerglide.
I am about to order an overhaul kit from Autotrans.
Now, the bands, bushings & washers are not included in the overhaul kit.
The transmission runs fine when driving. When selecting "drive" and reverse, it tends to jump slightly, and it does feel vaguely like it wants to surge forward when in neutral.
needless to say, it is leaking like a seive.
Would it be worth my while to order those other parts also?
'59 2 door Hard top Impala.
Whattya know, the levy really was dry!
Edited by Vic on 11-29-11 07:27 PM. Reason for edit: No reason given.
11-30-11 05:11 PM - Post#2163617
    In response to Vic
Personally I'd order them. IMO, you can never have too many spare parts for these old cars.
bowtieollie
bowtieollie
Reg: 12-06-99
11-30-11 06:35 PM - Post#2163647
    In response to Vic
Whenever rebuilding a transmission - it is imperative that a proper diagnosis be made PRIOR to tear down.
Otherwise, you may open it up and never see what may be wrong.
The "jumpy" feeling in both D and R is usually associated with a too high idle speed.
When was the last time the low band was adjusted?
I bet - never.......
Sure you can order the parts you mentioned and it is probably foolish not to install them during the teardown.
If it were not for the leakage issue, the transmission may not be as bad as it may seem.
If it were me, considering the labor involved - I would replace all soft parts.
Bowtieollie
Chevytalk.com Moderator
Vic
Vic
Reg: 09-20-11
11-30-11 07:47 PM - Post#2163676
    In response to bowtieollie
Thanks for that guys, better to do it well once than twice.
cool59belair
Reg: 03-05-02
12-01-11 09:01 AM - Post#2163785
    In response to Vic
Vic, IF possible take and post a BUNCH of pics as the rebuild will surely be interesting AND helpful to a lot of us. Especially IF you find worn parts or damage as it will give us an idea what to be aware of in our own cars. Good Luck.
yeah, you've got a nice car....BUT IT'S NOT A '59 !!!
Vic
Vic
Reg: 09-20-11
12-01-11 12:37 PM - Post#2163858
    In response to cool59belair
Ken, I have a digital camera with 4 gb of card space on hand. Am ordering the kit this week, and will notify when I start. Cheers.
Vic
Vic
Reg: 09-20-11
12-23-11 09:40 PM - Post#2171788
    In response to Vic
The kit arrived yesterday.
The transmission is out and on the bench ready to get 'de-leaked'.
Man that thing is heavy!!!
bowtieollie
bowtieollie
Reg: 12-06-99
12-24-11 07:19 PM - Post#2172108
    In response to Vic
She looks pretty clean already!
Bowtieollie
Vic
Vic
Reg: 09-20-11
12-25-11 05:42 AM - Post#2172172
Oh yeh, this was taken after the 2 hour scrape and soak.
Vic
Vic
Reg: 09-20-11
12-25-11 06:54 PM - Post#2172330
    In response to Vic
Have removed all the bolts from the servo cover, but it won't budge. I have given it a hearty tap with a block of wood and hammer, but no luck.
Other covers have shifted easily.
Any ideas? Experience tells me not to bash too hard until I am 100% sure that everything is clear.
[image][/image]
bowtieollie
bowtieollie
Reg: 12-06-99
12-25-11 08:53 PM - Post#2172355
    In response to Vic
Remove the vacuum modulator.
Then you may have to pursuade if off - since the paper gasket is probably holding it together
Bowtieollie
Vic
Vic
Reg: 09-20-11
12-25-11 11:03 PM - Post#2172378
Thanks for that. The schematics in the book made it appear to be self contained, so I didn't want to take of more than was necessary at any one time.
Vic
Vic
Reg: 09-20-11
12-28-11 08:31 PM - Post#2173395
    In response to Vic
Have progressed nicely with the pull down so far.
This is the first component that doesn't as good as everything else...input shaft bushing.
The area in question is at the uppermost of the bushing, noticeable with the fingernail. The rest barely felt.
Is this essential to replace? Common sense says yes, but waiting for delivery to Australia makes me question whether this is essential.
What would have caused this?
[image][/image]
bowtieollie
bowtieollie
Reg: 12-06-99
12-29-11 04:29 PM - Post#2173655
    In response to Vic
Hi Vic,
Can't suggest the cause of the damage - but it sure looks like something just "woodpeckered" that poor bearing to death.
Definitely requires replacement - as this is one of the main causes of the famous Powerglide BURP.
Not sure who you may be dealing with for parts...
www.fatsco.com is who I use and highly recommend.
Bowtieollie
Vic
Vic
Reg: 09-20-11
12-29-11 10:36 PM - Post#2173778
Thanks so much for that. Yes, I figure common sense....and patience must prevail.
I did get the previous kit from Autotrans, so I'll get back to him, but if I have no luck there, I will give you recommendation a go.
Cheers.
bowtieollie
bowtieollie
Reg: 12-06-99
12-30-11 03:39 PM - Post#2173973
    In response to Vic
Hi Vic,
Use a jaundiced eye on the input shaft seal and area in the main valve body that is rides against.
You will most likely find a groove in the main valve body that results from years of the shaft seal riding against it.
This is the 100% cause of the fluid leakage (burp) when the car sits for a period of time.
Now is the time to fix that....
Bowtieollie
Vic
Vic
Reg: 09-20-11
12-30-11 08:54 PM - Post#2174073
Trying to get an idea of what this means.
The shaft seal is a pressure fit, so I am wondering how that would create a groove?
Apologies for my ignorance.
bowtieollie
bowtieollie
Reg: 12-06-99
01-01-12 02:58 PM - Post#2174668
    In response to Vic
Hi Vic, sorry about the confusion.
Not the input shaft seal which rides on the torque converter.
The seal which is more "ring like" on the input shaft - from the torque converter - thru the main valve body.
If you have an exploded view from the factory service manual - it would be ite # 13
Located just forward of the lubrication hole in the input shaft.
Bowtieollie
Vic
Vic
Reg: 09-20-11
01-01-12 10:32 PM - Post#2174796
Do you mean this....?
bowtieollie
bowtieollie
Reg: 12-06-99
01-10-12 01:21 PM - Post#2177792
    In response to Vic
Hi Vic,
Sorry for the delay.... busy with work and my own '58 for a change.
Looks like the oil pump to me...
I am talking about the sealing ring which is on the input shaft. It seals inside the main valve body and usually wears a groove in the valve body.
The input shaft comes out of the converter and attaches to the front clutch drum - the seal is "approx. midway" on the shaft and is a steel ring.
Bowtieollie
Vic
Vic
Reg: 09-20-11
01-10-12 02:53 PM - Post#2177828
Ah, I see, the diagram is a bit vague, I thought the oil pump was a bit large for the pic. Yes, the sealing ring...one of those came with the seal kit and it is now installed.
This morning I get out to the garage before work and start the process of replacing the shaft bushings, and reassembling the unit.
Thanks do much for your guidance.
bowtieollie
bowtieollie
Reg: 12-06-99
01-11-12 06:45 PM - Post#2178331
    In response to Vic
Hi Vic,
The internal bore where this sealing ring resides is critical to prevent the BURP.
The sealing ring will wear a groove in the bore (which is the main valve body)
It can be machined or sleeved depending on the machine shop of interest.
Bowtieollie
Vic
Vic
Reg: 09-20-11
01-13-12 03:17 PM - Post#2179017
Cheers, I'll look into it.
Vic
Vic
Reg: 09-20-11
01-14-12 08:58 PM - Post#2179432
    In response to Vic
It looks like there was no scoring in the internal bore.
Also, how do you get the #%$# cover of the torque converter. The instructions say to simply lift it off. No joy there. I only want to replace the 'O' ring but am wondering whether I might leave it.
Any ideas?
Jens
58-60 Subject Matter Expert
Jens
Loc: Iowa.
Reg: 04-21-02
01-15-12 09:36 AM - Post#2179519
    In response to Vic
Vic, you should be able to take the the perimeter bolts out & tap on the outside edge a little and it should come apart.
Vic
Vic
Reg: 09-20-11
01-15-12 05:46 PM - Post#2179640
    In response to Jens
I took out all of the bolts and tapped more than just a little. More than I would have like, and it still didn't budge.
Decided not to persevere, so it is back in the housing and the tranny is about to go in.
bowtieollie
bowtieollie
Reg: 12-06-99
01-15-12 06:24 PM - Post#2179669
    In response to Vic
Ohhhhhhhh Vic,
If you removed all those bolts and tapped away and the cover did not come off???
Don' give up!
There is a 53 year old O-ring that is playing "I am the BOSS!" I would not trust it if the bolts were removed...
These are not the most "technician friendly" transmissions - especially when they are bolted to the car.
Great news about the "no groove" comment.
You can plan on painting your garage floor and enjoying that without the bloody red ATF leaking out if she sits for a few days.
Bowtieollie
Jens
Jens
Loc: Iowa.
Reg: 04-21-02
01-15-12 06:30 PM - Post#2179671
    In response to Vic
Try driving a chisel & wedge the 2 halves apart. They should go. There is a turbine & stator assembly in the housing pump you will want to clean and inspect before you put it back together. They are pretty basic componants. You don't want that old oil from your converter pumped through your fresh rebuild.
Vic
Vic
Reg: 09-20-11
01-15-12 08:01 PM - Post#2179711
Yes, great news about the groove! I have given up with the converter. I tapped as hard as I dared. I even put a dowel in the vice, and tried to poke it out from underneath.
And there is no way I am going to use a chisel!!! Thanks for the advice anyway. The book emphasises NOT to use a screwdriver to pry the cover off, I think a chisel probably fits in that category.
The tranny is now suspended on blocks, high enough to receive the modified trolley jack. All going well, it should be in by dinner time.
Pics coming soon.
Edited by Vic on 01-15-12 08:02 PM. Reason for edit: No reason given.
Vic
Vic
Reg: 09-20-11
01-16-12 03:18 AM - Post#2179789
    In response to Vic
One Powerglide transmission....IN!
30 kilometre test drive and so far....no leaks!
And so far, the garage flor is dry.
Here's a couple of pics of the install. Crikey that thing is heavy!!
Thanks for all of your comments and support.
Execution time: 2.582 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 01:15 AM
