Username Post: Photos of spark plug wire routing on small block Chevy engines.        (Topic#272319)
hosscartright
hosscartright
Loc: NW Central Indiana
Reg: 12-22-04
11-19-11 11:49 AM - Post#2159701
Howdy all,
While working on my 57,000 actual mile 1969 BELAIR, I took a bunch of photos before the tear-down. How wires and brackets attached etc..
When re-assembling the engine, I wanted to double check the heat shield positioning and spark plug wire routing. When I was Googling for this info, there wasn't much out there in Google images.
So upon re-assembly, I took some nice detail shots of the original way in which my car was wired and I added these spark plug wire routing images to my web page for this car. As the wiring layout was the same for many years, this should help others in the future. (Note the clamps that attach to the oil pan bolt which keeps the front two cylinder wires from coming into contact with the exhaust.)
I have these images now on my website and have placed a bunch of key words in the text.
When the Google-bot picks this up in a few months, these images should be easy to find for everyone.
For example, this is the name of one of these images;
Over and out, Jim
Edited by hosscartright on 11-19-11 11:53 AM. Reason for edit: No reason given.
Jerry Acheson
Jerry Acheson
Loc: Green Oaks, IL
Reg: 12-30-00
11-19-11 12:28 PM - Post#2159711
    In response to hosscartright
Thanks. What manifold paint are you using? They look good.
Jerry
hosscartright
hosscartright
Reg: 12-22-04
11-19-11 12:54 PM - Post#2159714
    In response to Jerry Acheson
Hi Jerry,
The paint is called "cast iron gray" from Bill Hirsch. Rated at 1,800 degrees F.. Five years on the '59 engine and so far still looks perfect.
Execution time: 0.214 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 08:18 AM
