Username Post: 96 CHEVY K1500 RAG JOINT CHANGEOUT        (Topic#270950)
496BBC
Loc: Louisiana
Reg: 01-28-07
10-22-11 05:05 PM - Post#2150023
How do you change the rag joint on a 96 K1500?
I've searched this form and can't find anything on this subject.
I've searched the net and can't find anything that says where to find one nor does the local parts house have them.
I have the steering shaft out and it appears that the rag joint is pressed onto the shaft.
Is it even possible to change it out?
thanks for any info
Neal
77 vette with 496BBC 10.5 to 1 Ross custom pistons, forged rotating assembly, custom ported large oval port heads, 2.19int, 1.88ext Lunati valves, titanium retainers, Lunati solid roller 258,260 dur,.698int,.701ext, 200R4 OD, 2800 stall, 4.11 rear
Edited by 496BBC on 10-22-11 05:06 PM. Reason for edit: No reason given.
sedandelivery55
sedandelivery55
Loc: Moore, OK
Reg: 02-20-02
10-22-11 06:05 PM - Post#2150035
    In response to 496BBC
Neal, if you have the shaft out, half the work is done. I replaced the ragjoint on my '92 last week, and like you said, the part store doesn't even carry a replacement. If you check out the 'Help section at autozone, you'll find replacement ragjoint kits with the rubber ring and replacement bolts, that's what I used.
You'll have to grind/drill the rivets out of the old joint and replace the ragjoint and use the bolts in the kit to replace the rivets.
The bolts in the kit I bought didn't work quite as well as I wanted, so I just used the rubber ring and my own hardware.
Lee
Sadly, the delivery is sold and gone.
Working on a '93 short/wide for the street scene.
496BBC
Loc: Louisiana
Reg: 01-28-07
10-22-11 06:25 PM - Post#2150041
    In response to sedandelivery55
Thanks for the info Less,
I'll run by there tomorrow and see if I can find one.
Neal
jvaagen
jvaagen
Loc: santa rosa ca
Reg: 03-16-11
10-22-11 07:52 PM - Post#2150067
From what I remeber from either this site or another you can remove the ragjoint completely and go with (I think a jeep) style steering shaft no parts to wear out. just do more research or ask around on this or a diffrent site?
1989 chevy k1500 5.7l 4x4 bone stock from bone yard
1987 vw cabriolet beater with a heater
10-22-11 08:38 PM - Post#2150081
    In response to jvaagen
You can use a Jeep shaft easily on an 88-94 truck; the redesigned column for 95-up makes it a bit more of a challenge as the shaft is different. Haven't yet seen someone find a Jeep shaft that can work for it.
And the Jeep shafts do wear; they have a U-joint instead of a rag joint and often the used shafts in the boneyards are no good.
jvaagen
jvaagen
Loc: santa rosa ca
Reg: 03-16-11
10-23-11 11:42 AM - Post#2150278
    In response to someotherguy
Oh my bad shows how much I know right, but the u-joint can be replaced easier than the ragjoint?
10-23-11 12:43 PM - Post#2150305
I do not believe the joints are serviceable, but I could be wrong. There are quite a few steering U-joints available but I'm having a hell of a time looking them up by the Jeep application.
At any rate, here's what the Jeep shaft looks like installed on a '94 pickup...
496BBC
Loc: Louisiana
Reg: 01-28-07
10-24-11 09:32 AM - Post#2150600
I have to agree that the hardware that comes with the repair rag joint is not adequate for the job. There just aren't enough bolts to complete the install. Not to mention that they don't work at all without interfering with the shaft clamp once installed.
I had to make a couple trips to the hardware store to get the correct fasteners to get it done.
Its installed and I'm back on the road, I still have a small amount of slack and that's due to some play in the output shaft of the steering box.
I'll either have to rebuild this one or install a rebuilt box latter when I have a little more time to do so.
thanks for all the help with this issue
Neal
12-29-14 09:57 AM - Post#2510093
Caution / second thoughts on Jeep steering shaft swap
Please read here: http://www.chevytalk.org/fusionbb/showtopic.php?fi...
Execution time: 0.447 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 10:11 PM
