jjchevy
Reg: 09-22-11
10-10-11 07:25 AM - Post#2145819
My check engine light came on a few days ago, had the codes checked out and autozone said they were p0171 and p0174. What does this mean. What should I check first or replace first. The lady at autozone was very unhelpful other than giving me the codes.
Also had to replace the altenator last night would that have caused those codes?
It is a 2006 silverado 5.3
Edited by jjchevy on 10-10-11 07:26 AM. Reason for edit: No reason given.
10-10-11 05:24 PM - Post#2146008
In response to jjchevy
Welcome to CT. Some great people on here. The alternator may have vaguely been connected to the codes. The codes are for lean fuel mixture on bank 1 (P0171) and bank 2 (P0174). A low voltage condition due to the alternator being bad could possibly have caused this.
If the codes are cleared and don't come back, then that was probably the problem. If they come back, you could have a dirty MAF sensor or possibly and air leak downstream of the MAF. You could also have a O2 sensor starting to go bad causing false readings and making the computer lean out the fuel mixture too much.
1957 Nomad sport wagon |
jjchevy
Reg: 09-22-11
10-11-11 06:33 PM - Post#2146403
In response to wagonman100
Thanks I cleaned my MAF and it seems to have cleared up the problem.
weee_willie
Loc: Milwaukee
Reg: 08-29-11
10-28-11 01:02 PM - Post#2152088
I too had the exact same problem with my 2006 Silverado 1500, 5.3L.
Cleaned the MAF..no help. Replaced the MAF with a rebuilt..no change. Installed New MAF...still no change. Now yesterday when accelerating, the engine rpm reved up but no power. After I parked at work and tried to start up after several hours, the engine would turn over & over but no start. A friend suggested banging on the fuel tank while turning the key and it started up.
Could this be.....gulp.....a bad fuel pump??
my mileage had been steadily decreasing. Down to 14.0 mpg. I was averaging 19.2 before all of this started.
10-28-11 02:33 PM - Post#2152112
In response to weee_willie
Starting after banging on the tank after a no start situation usually means the pump is done.
weee_willie
Loc: Milwaukee
Reg: 08-29-11
10-30-11 07:23 AM - Post#2152580
That's what I was afraid of. Dang truck isn't even paid off yet. There goes a truck payment!
Edited by weee_willie on 10-30-11 07:23 AM. Reason for edit: No reason given.
weee_willie
Loc: Milwaukee
Reg: 08-29-11
11-02-11 09:17 AM - Post#2153772
Problem solved. Had the fuel pump replaced and cleared up a couple up the problem, along with the radio buzzing.
Kind of an expensive solution for a vehicle that is only five years old.
Of course the warranty had expired!
Thanks for your help!
