Username Post: 98 Tahoe NP 246 Transfer case Fill Plug        (Topic#266453)
archie1407
Loc: Wyoming
Reg: 10-26-09
07-20-11 08:46 PM - Post#2116322
Anyone have suggestions as to how to remove the fill plug on the NP 246 transfer case. My 1/4" rachet is short and I tried to remove the plug but I fear the square hole is now round...
Is this why I've seen suggestions to replace the fill and drain plugs?
archie1407
Loc: Wyoming
Reg: 10-26-09
07-20-11 10:27 PM - Post#2116347
    In response to archie1407
Really wasn't planning on replying to my own post but I've been doing some investigating. Here's what I've found:
GM Service Bulletin # 99-04-21-001
Use of Heat for Difficult to Remove Transfer Case Fill and Drain
Plugs #99-04-21-001 - (03/29/1999)
Use of Heat for Difficult to Remove Transfer Case Fill and Drain Plugs
1998-99 Chevrolet and GMC K1-2 Suburban, Utility Models
1998-99 Oldsmobile Bravada
with NV136/246 Transfer Case (RPOs NP4, NP8)
This bulletin is being revised to add the 99 model year and part
information. Please discard Corporate Bulletin Number 76-74-03 (Section
7--Transmission).
Some transfer case fill and drain plugs may be difficult to remove. In some
cases, the plug may be "rounded out" attempting to remove the plug. These
plugs are made of aluminum and have a 1/4 inch square hole designed to
receive a 1/4 inch square drive extension. Installation torque may have been
too high causing difficulty in removal.
Caution
To help avoid a fire, thoroughly clean the area around the fill and drain
plugs of grease build-up before heating and use only an electric heat gun.
DO NOT USE AN OPEN FLAME. If sources other than an electric heat gun are
used, the transfer case may catch fire and cause personal injury.
In cases where the plugs cannot be loosened, the use of an electric heat gun
may make plug removal possible. Heat should be applied to the case around
the plug, not directly on the plug, for one to two minutes. Use only enough
heat to loosen the plug. Also, fully insert the 1/4 inch square drive
extension onto the plug before turning the plug.
Important
Do NOT use plugs made of steel or brass. These may cause a severe corrosive
reaction when in contact with the magnesium case, making future removal even
more difficult.
If the fill and drain plugs are damaged during removal and must be replaced,
use only aluminum replacement plugs. Replace the drain and fill plugs
(internal, square drive tool access design) with the EXTERNAL HEX DESIGN
plug, P/N 15032997.
When you install the transfer case fill or drain plug, tighten the plug to
20 N?m (15 lb ft).
Parts Information
P/N
Description
Qty
15032997
Plug, Transfer Case Oil Fill
1
355Cheyenne
355Cheyenne
Loc: Northern MN
Reg: 10-27-04
07-21-11 06:06 AM - Post#2116399
I have done this before but complete forgot what the plug looks like. Is it the same as a 3/8 racket but you are saying the end isn't long enough to work? Could you use a 3/8 drive extension to reach?
98 Silverado k1500 4x4 350
07-21-11 06:01 PM - Post#2116599
    In response to 355Cheyenne
Haven't had to mess with one of these transfer case plugs myself, but if it uses a square drive plug, there are actually sockets meant for this job that work a lot better than a ratchet or extension. Typically referred to as pipe plug sockets. Can sometimes be difficult to find but make tight plugs easier to remove without stripping them out.
archie1407
Loc: Wyoming
Reg: 10-26-09
07-22-11 07:55 PM - Post#2116969
    In response to someotherguy
Thank you...The square in the plug is 1/4". I tried using a "regular sized" 3/8 rachet with a 1/4" adapter...and broke the adapter from my allied tool set I got in high school 22 years ago. Will give it a go this weekend. I thought they made a socket for this kind of plug...local o'reilly and autozone didn't have them.
archie1407
Loc: Wyoming
Reg: 10-26-09
07-22-11 08:11 PM - Post#2116971
Sorry about not being too clear. When I put the 1/4 rachet in the square it was perpendicular to the ground, but the length of the rachet handle didn't go past the bottom of the transfer case...making it difficult to get a good grip to turn it. There is also a beam/brace that runs right in front of the fill plug...and I tried to use different 1/4" extensions but that beam/brace is about a 1/4" too tall and interrupts the proper seating of the 1/4" extensions. I did get a replacement from our local GM dealer. Was happy to see that it was an aluminum bolt(plug) and not a crappy 1/4" recessed fill plug. I'm glad I decided to try and get the fill plug out before I drained the fluid...The drain plug is the same 1/4" design, but of course, I was able to loosen it.
Execution time: 0.374 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 10:20 PM
