Username Post: Straight pipes burn valves?        (Topic#264084)
LukeMI
Reg: 06-03-11
06-03-11 03:14 PM - Post#2098974
Hi all, I am new here, I own a 1989 Chevy Silverado with a 350 small block, stock as far as I know, It was given to me by my grandpa this past october before he passed away. I recently straight piped it with no cat. A friend of mine told me that this could cause the valves to burn up because there is no back preassure. Is this true?
I currently have a 2.5" pipe that comes back to just behind the cab. plan on running it back to a Y pipe to duals then come out 3" apart on either side of the Reese hitch.
brainwashed2566
brainwashed2566
Loc: Idaho
Reg: 02-09-10
06-03-11 06:52 PM - Post#2099064
    In response to LukeMI
I've heard the same thing. I don't know if it is true or not but I drove around with a straight pipe for about a week before I could get my welder running again, and nothing bad happened. That was about 3 years ago and the engine is still running fine. Might just be a myth, or maybe it's more of a long term thing, either way I didn't like the sound or feel of the truck with nothing on the pipe.
-Charlie
If it ain't broken, fix it till it is
62chevy427
62chevy427
Loc: laurens sc
Reg: 04-13-06
06-03-11 07:06 PM - Post#2099071
keep on driving. straight pipes do not burn valves. sometimes they burn pocket books or billfolds when paying a fine for excessive noise.
56 bel air ((since 2002)
62 impala ss (since 1965)
65 el camino (since 1969)
66 nova (since 1987)
83 gmc 4wd (since 1991)
95 impala (new)
14 camaro (new)
06-04-11 04:51 AM - Post#2099172
    In response to 62chevy427
Another certainty is you'll lose a little low-end torque if you go completely straight piped - no cat or muffler. A cat does a pretty good job of being a muffler all on its own, so if you have one or the other you won't be ridiculously loud, and shouldn't notice a performance decrease. If you remove both...counterproductive, other than making a lot of noise.
Bill K.b
Loc: upstate NY
Reg: 10-24-05
06-06-11 06:12 PM - Post#2100218
    In response to someotherguy
My van was fine with nothing but manifolds on the test drive and drive home. The '91 came to me with no cat and duals cobbed on it and it was fine, but plus one on the lack of torque, even with a correct Y, cat and muffler on it's still kind of a dog.
One thing I also noticed with the '89 in my sig is when the muffler fell off and I was on the road and couldn't fix it right away, the milage dropped off a bunch too. Well, like from 15 to 11 or so.
Those who can, do. Those who can't, criticize it on the internet.
1988 G20 van 5.7L - driver.
1993 3500 dually 5.7L NV4500 - tow truck
1991 G20 van - parts truck
Plus cars for swap and sale
&yes, I once tried a frame swap on a 51 Chevy.
Randy_W
None
Reg: 01-06-02
06-07-11 03:03 AM - Post#2100347
    In response to Bill K.b
A quick primer; Straight pipes cut off at or near the manifolds can warp valves due to cold air reversion, not as likely on modern engines, but still possible. If you have at least 3 feet of pipe past the manifold you pretty much eliminate that problem.
The back pressure issue gets beaten to death. Back pressure is always bad, period. It's also unavoidable. The reason you often lose torque with straight pipes or dual exhaust is that your system is improperly designed and sized for optimal performance. Welcome to the world, they all pretty much are. The factory isn't interested in your 1/4 mile times in your Silverado.
In most systems when you take out the muffler and cat, your system is too big to maintain exhaust gas velocity so your cylinders don't scavenge well. On a truck like yours a good y pipe to 3" single running through a 3" Magnaflow with a single 2.5-2.75" tailpipe would be nearly ideal. The reason the tailpipe is smaller is because as the gasses travel through the pipe they cool, thus slowing down, so smaller pipe is need to keep the speed of flow up.
Randy
DON'T mess with Old Men, we didn't get old by being, STUPID!!!
"The veneer of civilization is very thin!" (Arlo)
355Cheyenne
355Cheyenne
Loc: Northern MN
Reg: 10-27-04
06-07-11 05:43 AM - Post#2100396
    In response to Randy_W
Right on. I would also like to add that the only benefit to some amount of back pressure is for the o2 sensor. From my understanding, if you uncork an exhaust with a non heated o2, the exhaust wont be able to heat that o2 sensor up enough at low rpm so you could see additional costs in reduced fuel economy particularly in stop and go and idling environments.
98 Silverado k1500 4x4 350
Randy_W
None
Reg: 01-06-02
06-07-11 05:15 PM - Post#2100704
    In response to 355Cheyenne
Even that would be fixed with proper sizing and shape.
Randy
355Cheyenne
355Cheyenne
Loc: Northern MN
Reg: 10-27-04
06-07-11 08:11 PM - Post#2100767
or a 3 wire o2 sensor. Always a solution.
Bill K.b
Loc: upstate NY
Reg: 10-24-05
06-07-11 11:41 PM - Post#2100801
Unless someone's changed one for whatever reason, TBI trucks with a non-heated O2 have it in the left manifold outlet. That should pretty well keep it warm as long as some kind of Y-pipe is on the truck.
Randy_W
None
Reg: 01-06-02
06-08-11 03:14 AM - Post#2100823
In the manifold usually will keep the heat up but anytime I significantly free up exhaust, I like to use a heated sensor. Not always required, but cheap insurance.
Randy
06-08-11 03:21 AM - Post#2100826
I'm thirding it.
JustRedneckit
Reg: 12-11-13
12-11-13 11:13 AM - Post#2406733
Now i drive a 06 silverado and right behind the headers there is a manifold with 2 bolts and if you undo these bolts its pretty much the same as straight piping it, now I was told not to do it cause it ruins the valves cause now I don't have enough back pressure...... is this correct?
Allan In NE
Reg: 12-27-11
12-11-13 01:20 PM - Post#2406764
The "Back Pressure" tale is pure uncut BS. Who starts these stories anyway?
"Short" straight pipes could possibly 'warp' a stem by letting cold air in on that hot valve.
Allan
Lifelong GM automatic transmission specialist
bowtie44s
bowtie44s
Loc: wv
Reg: 08-29-12
12-11-13 02:11 PM - Post#2406773
    In response to JustRedneckit
Manifold behind headers? I have no clue what you're talking about. You'll probably run into a lot of problems with straight pipes on an 06. This is really the wrong forum for an 06 though.
Drag cars, pulling trucks, and a lot of other rigs run open headers and don't burn valves. I've never heard that tale before.
Jeff
'88 Chevy K3500, aluminum head roller cam 511inĀ³ stroker 10.5:1 compression, 96 NV 4500, 94-98 grille, 305/70-16 (33x12) BF Goodrich KM2s, 91 cluster swap
Hwasiecko
Reg: 05-07-14
05-07-14 11:21 AM - Post#2450931
Theoretically no engine needs back pressure but cars that don't variable fuel control need to be tuned to compensate for the loss of back pressure. So basically if your car has a carburetor or the fuel injection system can't adjust to match the air/fuel ratio you'll burn lean because there will be increased air flow. So make sure your car has a good fuel injection system or one of those carburetor a that automatically a just the mixture.
Execution time: 0.413 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 09:14 AM
