41 Years of Service
Username Post: CPP 500 vs. Borgeson 600        (Topic#262796)
Rocki
Rocki
Loc: Hartland, Michigan
Reg: 06-17-05
05-11-11 08:29 AM - Post#2088622
Aaron -
Tell me why your CPP 500 steering box is better than the Borgeson 600. As I understand things, the Borgeson doesn't have the radiator interference issues on the 61-64 Impalas that your box does on certain installations.
What installations for the 61-64 Impalas do not require modifying the radiator for clearance with your box?
Thanks.
64 Impala SS Convertible (undergoing frame-off resto and upgrades)
62 Impala SS Convertible Anniversary Edition 409/409, 4 speed (recovering from engine fire)
65 Mustang GT Convertible, 289, 4 spd (wife's toy)
Dreaming of more...
cpptech
cpptech
Loc: CA. USA
Reg: 12-08-06
05-12-11 10:08 AM - Post#2089129
    In response to Rocki
Hello Rocki,
The CPP box is 100% brand new inside and out. The Borgenson is a nice remanufactured unit. The fitment with larger radiators is better with the borenson if you are trying to retain a stock 4 core. If you are running the aftermarket newer radiators like Griffin or US radiator there is a provision in the lower tank to fit the 500 series now. With the CPP the main benefits are the New construction, SAE inverted flare fittings, 3/4x30 spline rag joint (same as 605 conversions)
The Borgenson is a metric 18DD input shaft and o-ring fittings.
CPP Retails for $389.00...
Both are nice products and we do carry the 600 as well!
Thanks,
Aaron @ Classic Performance
800-522-5004
Execution time: 3.917 seconds.   Total Queries: 12   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 01:24 AM
