Username Post: 1998 vortec 454 timing?        (Topic#261283)
98beast
Reg: 04-15-11
04-15-11 06:37 PM - Post#2077241
so my vortec's M.I.L. is on with a p1345 trouble code: cam/crank correlation my timings at 20-25* around 1200rpm sapose to be 0-2* to be inspec ive tried my disbritor a tooth over in both directons an it dosent change it..is my cam sensor messed up? ive heard the cam sensor is what cuases the p1345 code any help or any educated guess's would be apprieciated-J
04-16-11 03:20 PM - Post#2077545
    In response to 98beast
Put the timing light away; it's useless to you on a Vortec. You need a scan tool that can read the "cam retard" figure. With RPM's held at 1,000 or more, the cam retard must read within +/- 2 degrees of zero. You adjust the distributor until you get this.
If you set it this way, clear the codes, and P1345 returns then the distributor is the most likely suspect as it's probably badly worn. Before you remove it make TWO marks - distributor body position, AND rotor position - install the new distributor as close as humanly possible to those two marks, then use your scan tool to fine-tune the timing as specified.
Execution time: 4.6 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 02:40 PM
