Join the Community today
Username Post: 2004 Malibu Classic turn signal clicking keeps clicking        (Topic#258538)
96Lumi
Reg: 04-14-04
03-02-11 05:04 PM - Post#2054808
Hi. I have a 2004 Malibu Classic, and the turn signal clicking sound keeps clicking after the signals have cancelled. Could it be the turn signal switch going bad?
algopher
Deceased Member
algopher
Loc: Semmes, AL
Reg: 04-09-01
03-02-11 07:42 PM - Post#2054888
    In response to 96Lumi
When does it go off, when the ignition switch is turned off? Could be the flasher.
67 Shaggin Camaro
03 ZQ8 S10
USCG(ret)
96Lumi
Reg: 04-14-04
03-02-11 08:18 PM - Post#2054908
    In response to algopher
Yes, it stops when the ignition is turned off. It starts clicking whenever the engine is on, and then also seems to slow down in pace as I brake and stop, keeps clicking, then returns to a constant "click click..." as the engine gets back up to speed.
DEI8FAN
DEI8FAN
Loc: Western, N. Carolina
Reg: 02-01-05
03-03-11 04:15 AM - Post#2054964
I do a lot of used car work and had that same problem once. Turned out to be a bad hazard light switch.
1959 El Camino
1970 El Camino
1981 Corvette
2004 Z71
2005 Monte Carlo
96Lumi
Reg: 04-14-04
03-03-11 06:10 AM - Post#2055026
    In response to DEI8FAN
Thank you, DEI8FAN and algopher. I will check into a replacement hazard light switch. Are those easy to replace myself?
96Lumi
Reg: 04-14-04
03-12-11 01:18 PM - Post#2060399
I replaced the hazard light switch, but the clicking noise is still there. Could it be the direction signal stalk assembly unit on the steering wheel that needs replaced?
DEI8FAN
DEI8FAN
Reg: 02-01-05
03-13-11 03:46 AM - Post#2060655
I found this on another site.
The noise you hear is indeed the flasher clicking. It is the hazard flasher which also controls the turn signal flasher. This is caused by worn contacts in the turn signal switch in the steering column. These are very easy to change. THe top cover of the steering column pops off and then there is one screw and 3 connectors. The only thing to watch for is the horn contact pin that needs to be pushed in to slip behind the horn contact.
Also I found out if you take the switch apart and clean the contacts it will stop.
1959 El Camino
1970 El Camino
1981 Corvette
2004 Z71
2005 Monte Carlo
96Lumi
Reg: 04-14-04
03-15-11 05:46 PM - Post#2062277
Thank you, DEI8FAN. I will clean the contacts first to see if that works, so I can possibly avoid (for now) paying around $100 for a replacement.
96Lumi
Reg: 04-14-04
03-18-11 06:24 PM - Post#2063678
Before I tackle this job, should I disconnect the airbag somehow? I'm nervous about having my face so close to the steering wheel in order to see and locate what I need to mess with in order to remove the turn signal switch off the column.
DEI8FAN
DEI8FAN
Reg: 02-01-05
03-20-11 03:26 AM - Post#2064201
Yes disconnect the battery and wait 10 minutes.
1959 El Camino
1970 El Camino
1981 Corvette
2004 Z71
2005 Monte Carlo
CCBlue
CCBlue
Loc: SoCal
Reg: 04-17-08
05-17-11 08:27 AM - Post#2091253
I am having a issue with the driver front blinker. Sometimes it works and sometimes it doesn't. When it doesn't the flasher gets faster like the bulb is out.
Any ideas?
1966 Chev Impala Wagon - 454, 4L60
1967 Chev Chevelle Malibu - 327, Powerglide..Sold
2002 Chev Silverado 1500HD
2007 Chev Suburban LTZ
66 Impala Wagon
monte-77
monte-77
Loc: Western New York State
Reg: 06-04-06
05-18-11 01:53 AM - Post#2091578
    In response to CCBlue
The turn signal stalk is probably going. If you pull it slightly foward towards you it probably will work.
Dave
Takin' care of business.
77 Monte Carlo, 75 Laguna S-3, 77 Malibu Classic, 84 Impala, 98 Z34 Monte, 16 Equinox, 2011 Impala, 06 Pontiac Grand Prix, 95 Monte Carlo Pace Car
http://www.hemmings.com/hcc/stories/2010/12/0 1/hmn...
Execution time: 0.19 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 07:17 AM
