Username Post: home made posi lock?        (Topic#256813)
aerosedan42
Loc: Oregon
Reg: 07-20-08
01-31-11 07:00 AM - Post#2039943
I was looking at buying a posi lok for my '88 GMC last year and someone on here made thier own much cheaper. I am looking for how to do this and what I would need to do it. I hate to spend $200 if I can do it for less myself. I can use the money I save for something else car related for my '42 Chevy car.
trailwart
Reg: 04-17-08
01-31-11 05:02 PM - Post#2040188
    In response to aerosedan42
do the actuator upgrade. you buy the dorman harness kit that includes a spacer(costs 30-50$ depending on source) and pick up a new actuator and have a bit over 100$ into it. but if your to cheap to buy new, get a used actuator from the junkyard for 10$ but the harness will cost up to 50$. you splice 1 wire and its plug and play.
Obtain the following GM part numbers:
(1) 26060073 Actuator
(1) 88959465 Harness/Spacer Kit
nickmac
nickmac
Loc: Tennessee
Reg: 02-13-07
01-31-11 06:57 PM - Post#2040243
    In response to trailwart
I agree with trailwart. And I have the same GM numbers too. Don't forget to add the spacer.
Dan
'16 Chevy Traverse 3.6 FWD
'04 Chevy K1500 Silverado 5.3 4x4
aerosedan42
Loc: Oregon
Reg: 07-20-08
01-31-11 07:25 PM - Post#2040261
    In response to nickmac
Thanks. That sounds like a good way to go. Is it more reliable then? When I want 4 wheel drive I need it , like snow or ice.
trailwart
Reg: 04-17-08
01-31-11 07:37 PM - Post#2040266
yes it is the way to go. i did this to my 94 and it works the same as my 99. the newer style (upgrade)is nice in a few ways, when you shut the truck down with the front engaged- it will stay engaged. with the old style actuator it would disengage. engagement is instant with new design, old style would have to heat up and engagement could be hit or miss at times.
trailwart
Reg: 04-17-08
01-31-11 07:38 PM - Post#2040268
and yes, old style is thermal, new style is electric.
aerosedan42
Loc: Oregon
Reg: 07-20-08
01-31-11 07:50 PM - Post#2040273
Where can you get them for a decent price? So far online it looks like at least $100 or more.
Matt
Matt
Loc: SAV
Reg: 09-26-01
01-31-11 08:18 PM - Post#2040296
rockauto.com
car-part.com
aerosedan42
Loc: Oregon
Reg: 07-20-08
02-03-11 01:13 PM - Post#2041537
    In response to Matt
If I get both of these will it come with the spacer you mentioned? I am going to go with this setup. Changing it will make it work more reliably. Thank you for the help, you guy's are great.
trailwart
Reg: 04-17-08
02-03-11 06:47 PM - Post#2041694
spacer is included in the harness kit..
when i did my 94, you have to splice into the brown wire that goes to the tcase. i made my splice inside the truck at the 4x4 shifter area. it made my splice inside the cab, out of the elements.
nickmac
nickmac
Loc: Tennessee
Reg: 02-13-07
02-03-11 07:05 PM - Post#2041698
Brown wire on my 91 also, should be the same for you too.
Dan
Execution time: 0.735 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 08:52 AM
