Username Post: 327 Cam        (Topic#253235)
69_BOWTIE
Loc: WYOMING,USA
Reg: 02-27-02
11-23-10 05:22 PM - Post#2008617
I am looking at replacing my rv cam (melling #1730) in the 327,engine is in my 69 C-10 SWB.The motor came from a 63 Impala,I have put 202 Camel heads(light ported)#461, a Edel. performer and edel. 600 carb.Hei,and Hedman headers.Trans. is a TH-350 with a 2k stall and 3:73 gears.Comp cam suggested the XE-268, a friend of mine thought it might be a little to much what are your guys thought s on it would the XE-262 be better suited for this?I am not sold on a Comp cam have looked at the Lunati Voodo cams as well as a millon other,just thought I would ask you guys .Appreciate all the help and advice from you
2001 Silverado 4X4
2005 FXDWGI
69 CHEVY Short Step
63 IMPALA 2/DR HRDTOP 327
Edited by 69_BOWTIE on 11-23-10 05:23 PM. Reason for edit: No reason given.
jdk
jdk
Loc: columbus, ohio
Reg: 02-15-10
11-23-10 06:23 PM - Post#2008672
    In response to 69_BOWTIE
don't know the number, but speedpro i think sells them as does napa. it is the L79 hydraulic cam. better torque than the 097 and 30 30 cam but does not wind as high. i loved the L79 engine. jim
C10 Sleeper
C10 Sleeper
Loc: Redding Ca
Reg: 03-17-09
11-23-10 07:40 PM - Post#2008709
    In response to jdk
What's your compression ratio, tire sizeand intended use?
http://photobucket.com/C10Pictures
69_BOWTIE
Loc: WYOMING,USA
Reg: 02-27-02
11-23-10 09:18 PM - Post#2008764
    In response to C10 Sleeper
I belive the comp.ratio is around 9.5:1 and tire size 28"tall 275/60/15.I only have about 421/443 lift 270/280 adv.dur. melling rv cam.in it at this time.It gets great mpg but I am willing to give up some for some hp/torque.I just want a fun little truck with a little more lope.
2001 Silverado 4X4
2005 FXDWGI
69 CHEVY Short Step
rumrumm
rumrumm
Loc: Macomb, IL
Reg: 10-18-01
11-24-10 07:58 AM - Post#2008884
I don't necessarily agree that the XE-268 would be a little large for your 327. It works great in a 350, but it is pretty mild. I like Lunati's Voodoo 60102 cam much better: 219/227 dur @ .050, .468/.489 lift, ground on a 112 deg. lobe center. Similar specs to the XE-268 but it is not as hard on the valves. It is a later development by the guy who designed the XE series for CompCams. If you are afraid it is going to be too big, you can always go with an XE-262 or the Voodoo 60101 cam. You can see the specs for the 60102 here:
http://www.lunatipower.com/Product.aspx?id=1983&am...
Be sure to use the recommended valve springs with it.
Lynn
"There's no 12-step program for stupid."
383 sbc, Eagle, AFR, SRP, CompCams, Edelbrock, FiTECH. Dyno #'s: 450 hp @ 5700, 468 ft. lbs. torque @ 4300.
http://photo.net/photos/Lynn%20Johanso n
Edited by rumrumm on 11-24-10 08:06 AM. Reason for edit: No reason given.
Alby63
Alby63
Loc: NJ
Reg: 08-29-10
11-24-10 09:09 AM - Post#2008910
    In response to rumrumm
I have a voodoo 60101 cam in a 327 installed in a Jeep. It's a nice responsive cam. Idles smooth and sounds nice. No problems idling in gear with the automatic. I also have 3.73 gears and a 2000 stall converter. Pulls good with 35" tires. If it was two wheel drive, I would have went with the 60102 cam.
'82 CJ5, glass body, 327, Holley Stealthram Pro 950 EFI, B&M Turbo350, Dana 44/30, Lockers, 3.73's, 6-1/2" lift, 35's, stnlss mustang SLP exhaust
69_BOWTIE
Loc: WYOMING,USA
Reg: 02-27-02
11-24-10 10:50 AM - Post#2008945
    In response to Alby63
I had asked comp and lunati what they recommened and comp was the xe-268 and Lunati was the 60102.My motor was redone a few yrs back I would say I have about 3-4 k easy miles,the machine shop said I could easily go with a 500 lift on my springs.
2001 Silverado 4X4
2005 FXDWGI
69 CHEVY Short Step
Alby63
Alby63
Loc: NJ
Reg: 08-29-10
11-24-10 11:51 AM - Post#2008956
The Voodoo cam (ground on a 112 deg LSA) will give you a better idle and more vacuum at idle. It will also lower your chances of engine knock and move your torque up to work better with your torque converter.
69_BOWTIE
Loc: WYOMING,USA
Reg: 02-27-02
11-24-10 12:10 PM - Post#2008961
What kind of idle does it have choppy or smooth?I would prefer a noticable/choppy idle.Appreciate the help
2001 Silverado 4X4
2005 FXDWGI
69 CHEVY Short Step
Alby63
Alby63
Loc: NJ
Reg: 08-29-10
11-24-10 01:49 PM - Post#2008995
The CompCam will give you that nice choppy idle.
MikeB
MikeB
Loc: Plano, TX
Reg: 08-28-03
11-25-10 11:52 AM - Post#2009380
Hard to beat the Lunati Voodoo cams recommended above, but I doubt if either will have much of a lope. Same goes for the Comp XE268.
Lope is typically a function of overlap, the period when both intake and exhaust valves are open. You can get more overlap with more duration or a tighter LSA (lobe separation angle). If you have 4 different cams with 268 advertised duration, the cams with 112 & 114 LSA will idle smoothly, the one with 110 LSA may have just a slight lope, and the one with 108 will have a more noticeable lope.
I think this Isky cam will give you a nice lope without going overboard on duration and killing your low-mid RPM torque.
http://www.summitracing.com/parts/ISK-201271/
The tight LSA will concentrate power in a narrower RPM range, which means it will have a strong mid-range hit. Perfect for your 3.73 gears and 2K converter. You should check with Isky to see if it will work with your compression. I didn't look at the timing card, but it will close the intake valve sooner than a 110 or 112 LSA cam, which means it will make more cylinder pressure.
Edited by MikeB on 11-25-10 11:58 AM. Reason for edit: No reason given.
NYH1
Loc: Central New York
Reg: 07-15-09
11-25-10 02:08 PM - Post#2009435
    In response to MikeB
I'm running the Lunati Voodoo 262/268 cam in my 385 stroker. I wanted a cam that worked off idle to 56/5800 RPM's and made good low end torque and mid range power. It works great. My engine pulls 20 inches of vacuum at idle and 17 to 18 inches at regular cruise speeds. The idle is pretty smooth. I've never used it in a 327, but it's an absolute stump puller in my setup.
'78 Camaro, mild Vortec head 385 stroker, 9.1 comp. Lunati Voodoo 262/268 hyd. ft. cam, RPM Intake, 650 AVS carb, TH350 Coan 11" 2600 stall, 8.5" 10 bolt. 3:42 posi, 1 5/8" Full length Headers, 2 1/2" Flowmaster Exhaust System.
Wheels56
Loc: CA
Reg: 02-17-02
11-26-10 08:40 AM - Post#2009672
    In response to NYH1
The Isky cam will definitely have a lope. I am running the next cam smaller - Isky Mega 264 - in a 350 and it has a slight lope at idle but comes on strong right off idle and pulls hard. If your 327 has cast pistons and not forged they are most likely .040 down in the hole and your compression is closer to 9:1 with your 461 heads. I would take a serious look at the MEga 264 for your application. If its running fine with the RV cam you will be very happy with the MEga 264.
Edited by Wheels56 on 11-26-10 08:42 AM. Reason for edit: No reason given.
69_BOWTIE
Loc: WYOMING,USA
Reg: 02-27-02
11-26-10 02:22 PM - Post#2009797
    In response to Wheels56
Yeah it runs great if you like a pretty much stock cam.Have no issues at all just want a little more giddy up
2001 Silverado 4X4
2005 FXDWGI
69 CHEVY Short Step
Wheels56
Loc: CA
Reg: 02-17-02
11-28-10 12:48 AM - Post#2010391
The Isky Mega 264 will close the intake in about the same position as the cam you have now but has more overlap and more duration at .050. It will have a slight lope at idle and a better mid range and should rev better as well.
Weccemah
Weccemah
Reg: 03-16-08
12-01-10 01:15 PM - Post#2012134
I had the Comp Cams 262 Xtreme in a 327 in my Impala and I really liked it. The thing is though that I changed the camel hump heads out for aluminum ones and increased the exhaust pipe diameter all at the same time, so I cant really comment on the difference between cams alone. It replaced an "RV" cam though and I liked it alot for a 327. You wouldn't go wrong with it IMHO.
1964 Chevy Impala SS
Execution time: 2.559 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 08:54 PM
