Username Post: cant siphon gas        (Topic#251256)
mag
Loc: mpls mn
Reg: 01-04-05
10-20-10 05:27 AM - Post#1992225
Cant get a tube down my 61 to get last years gas out. Is there a baffle of sorts in the tube? 9/16 diameter hose. Have last novembers fill still in tank, hardly drove it due to work 90 octane nonoxygenated with can of seafoam. Would like to put fresher gas in before storage. It sits without starting it here in minnnesota. Thanks for your help.
Dave_Neiling
Loc: Custar, Ohio United State...
Reg: 12-10-01
10-20-10 05:37 AM - Post#1992229
    In response to mag
no baffle should be able to get in with a flexible hose, mabey its getting stuck at the area between the filler neck and the gas tank at the rubber section that conects the two parts also try a smaller hose.
Dave N.
62BillT
62BillT
Loc: Moneta, VA
Reg: 09-24-01
10-20-10 05:52 AM - Post#1992232
    In response to Dave_Neiling
It may have a Gas Guard. Back in the '70's during the gas shortage, people would install guards to prevent their gas from being stolen. Some of them are visable and others are down deep and hard to see.
Bill
Member:
-National Impala Association
64ss409
Reg: 12-04-02
10-20-10 06:18 AM - Post#1992238
    In response to 62BillT
Unhook the hose at the fuel pump and put a little air pressure in the tank.
Ron
Dave64SS
Dave64SS
Loc: Cypress, TX
Reg: 02-28-09
10-20-10 08:16 AM - Post#1992281
    In response to 64ss409
OK, I'll bite on this comment? The gas tank is vented. So with the gas cap off and trying to get a hose in the tank, how is putting air into the gas feed line from the engine going to help????
62BillT
62BillT
Loc: Moneta, VA
Reg: 09-24-01
10-20-10 08:56 AM - Post#1992295
    In response to Dave64SS
I believe he is saying to put the air pressure at the gas filler and let it pump out of the gas line (before the fuel pump).
Bill
Member:
Dave64SS
Dave64SS
Loc: Cypress, TX
Reg: 02-28-09
10-20-10 10:53 AM - Post#1992364
AHHHHHH.....o dopey me....
64ss409
Reg: 12-04-02
10-20-10 06:05 PM - Post#1992542
Yes that is what I meant. I bought a 62 vert last Nov that had not been run for 25 years. The gas really stunk! That is how I got the gas out. I put a longer rubber hose on the fuel pump end so I could catch in in a 5 gal bucket. Then I put in about 2 gallons of fresh gas and pushed it out again. I repeated, and after the 3rd time, the rotten gas was out.
Ron
Edited by 64ss409 on 10-20-10 06:07 PM. Reason for edit: No reason given.
Chevrobert
Loc: Braintree, Ma. USA
Reg: 06-14-08
10-20-10 06:44 PM - Post#1992575
How long is the Sea Foam good for?
Bob
'64 Impala SS
'77 Pontiac Ventura SJ
Ain't to proud to think out loud.
doubleE
doubleE
Loc: Eagan MN
Reg: 06-02-03
10-21-10 04:24 AM - Post#1992715
Ron, that is a clever solution but I wonder what condition the "sock" screen filter is in that is at the bottom of the fuel pick-up tube, inside the tank. I would think 25 years would have built up alot of crud. You would want to run an "in line" fuel filter before going into the fuel pump to play it safe.
Eric
64ss409
Reg: 12-04-02
10-21-10 05:41 AM - Post#1992733
    In response to doubleE
I put in an inline filter after the "flush", just ahead of the fuel pump. I ran it for a while, removed, and cut it apart to check for crud. It was pretty clean. Nice surprise.
Ron
Dave64SS
Dave64SS
Loc: Cypress, TX
Reg: 02-28-09
10-21-10 06:31 AM - Post#1992745
well..to me, two bolts and 2 hose clamps loosened up and you can drop the tank and clean the tank and the filter....Seems the easiest and most thorough way to attack this beast....
Chevrobert
Reg: 06-14-08
10-21-10 07:56 AM - Post#1992775
    In response to Chevrobert
Hey guys,
Related,
General knowledge,
experience specific..
What is the longest period y'all would trust treated gasoline?
Would you store a car fuel free if it was gonna sit for a year?
Bob
'64 Impala SS
64ss409
Reg: 12-04-02
10-21-10 08:49 AM - Post#1992797
Removal is the best way. If I had gotten any rust particles during the flush, I would have removed it for cleaning.
This car was sitting in a garage during those 25 years.
Ron
Chevrobert
Reg: 06-14-08
10-21-10 08:59 AM - Post#1992802
You guys are making me insecure.
Are you ignoring me cause I have a little
motor?
Bob
'64 Impala SS
impala
impala
Loc: Pittsburgh, PA USA
Reg: 07-13-00
10-21-10 02:05 PM - Post#1992909
Ollie on here has a good fuel recipe that he says lasts years.
Maybe he'll respond.
impala
61 Impala Convertible, AACA 1st. Grand National
99 Jaguar, XK8
11 Silverado
15 Malibu
tony1963
Loc: Birmingham AL
Reg: 10-11-08
10-21-10 05:52 PM - Post#1992997
    In response to impala
The easiest solution, by far, is to simply drop the tank and replace it with a new tank, sending unit and pickup screen.
Total time about 1.5 hours and about 120 bucks.
1964 Chevrolet Impala SS 327 Powerglide (SOLD!)
1981 Ford Granada 3.1 L (200 inline 6) (SOLD!)
1985 Chevrolet Suburban C20 454 Turbo 400
1999 Mercedes E300 (SOLD!)
2008 Mercedes E350
2012 Mercedes S550
daustin
Loc: Woodstock, Ga
Reg: 12-03-08
10-27-10 09:15 AM - Post#1995782
Seafoam isn't a fuel stabilizer, it's a cleaner type fluid. Sta-bil is a fuel stabilizer, i've used it with great success in the past. They say properly treated fuel is good for about a year, i've stored fuel for 2 years with Sta-bil and it ran just like new gas when i used it. I did store it in a new air-tight plastic tank, in a side stall on my garage that was heated/cooled.
1957 210 2d Post
1961 Bubbletop Impala
1965 Buick LeSabre
1968 327 Camaro
1968 427 COPO Corvette
1984 Monte Carlo SS
1969 RS Camaro
1969 GTO
1976 Camaro
1993 Silverado 3500 Dually 6.5TD
1993 GMC 1500
1994 9C1 Caprice
1997 Silverado 1500
Execution time: 0.382 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 10:11 PM
