Username Post: '99 5.3 Coolant Leak        (Topic#247329)
94C1500
94C1500
Loc: Dickson, TN
Reg: 07-09-03
08-12-10 10:01 AM - Post#1959944
Hey guys I've got a coolant leak that requires me to add coolant every couple of days or so.
Recently I've noticed a small wet spot under my parking spot at work. I looked under the truck today and saw a little antifreeze dripping from the back of the skid plate. And yes, I know it could be coming from anywhere with such vague information.
As of now that's all the info I have but I'm hoping that some of you could list the most common areas to leak coolant on our trucks.
This weekend I'll have time to really look things over.
Thanks in advance.
13 Silverado Z71
99 Silverado Z-71 - Sold
94 Silverado Sportside
66 Chevelle 300 Deluxe
68 El Camino
74 El Camino - Gone
Edited by 94C1500 on 08-12-10 10:16 AM. Reason for edit: No reason given.
LMC Trucks
Bad Bowtie
Bad Bowtie
Loc: TX
Reg: 07-04-03
08-12-10 11:14 AM - Post#1959993
    In response to 94C1500
Intake manifold or heater hose nipple (5.7L Classic '99)...
mwright1
Loc: Naperville, IL
Reg: 04-05-04
08-12-10 11:47 AM - Post#1960014
    In response to Bad Bowtie
Water Pump?
If it ain't broke open it up and make it better 03 Silverado 5.3 Z71
Alan_W
Alan_W
Loc: Little Rock, AR
Reg: 10-15-02
08-12-10 12:23 PM - Post#1960026
Water Pump Gasket. Common problem with these models. I'm surprised yours lasted this long.
Depending on miles, maybe the water pump also.
2000 GMC Sierra SLE 3Dr. X-cab
2WD/5.3/auto/3.73
94C1500
94C1500
Loc: Dickson, TN
Reg: 07-09-03
08-13-10 04:52 AM - Post#1960329
    In response to Alan_W
I have a feeling it may be the water pump. I'm going to have to get under it with a shop light to see. I still couldn't tell where it's coming from when I was crawling under the truck yesterday afternoon.
I appreciate the responses. I'll report back what I find out.
13 Silverado Z71
68 El Camino
74 El Camino - Gone
Alan_W
Alan_W
Reg: 10-15-02
08-13-10 05:25 AM - Post#1960341
I got by for now on mine just replacing the gasket, but it could be time for a new water pump for either of us.
Take heart, though, it is not a very hard or long job.
2WD/5.3/auto/3.73
94C1500
94C1500
Loc: Dickson, TN
Reg: 07-09-03
08-16-10 03:54 AM - Post#1961640
Turns out it was indeed the pump. My handy dandy inspection mirror helped me confirm that the coolant was leaking from the weep hole on the bottom of the pump snout and running down the engine then back to the skid plate.
One thing I learned about removing the fan: I had forgotten to look for the strap-type wrench to hold the pulley while loosening the fan as the pressure of the accessory belt wasn't enough after 190,000 miles (never replaced water pump till now.)
If you fish a clothes hanger thru the un-used threaded holes of the pump pulley and tie it around the alternator bracket, it will hold the pulley just enough to loosen the fan nut.
13 Silverado Z71
68 El Camino
74 El Camino - Gone
LMC Trucks
Execution time: 0.22 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 10:10 PM
