Username Post: finding tdc heads off        (Topic#246870)
mightymouse22
Loc: Kelso, WA
Reg: 03-17-09
08-04-10 07:01 PM - Post#1955883
hey guys, getting the bottom end of the 489 buttoned up, so far i have the rotating assembly done and just got the cam in, want to install the timing chain and start degreeing the cam for my first time, how do i know if tdc is on the compression stroke or exhaust stroke, without the heads and chain on. THANKS
08-04-10 07:29 PM - Post#1955895
    In response to mightymouse22
Without the chain, it doesn't matter. The cam timing determines which stroke its on.
greg_moreira
Reg: 10-06-03
08-04-10 09:28 PM - Post#1955949
    In response to acardon
correct. The valves determine whats happening(whether its the compresion stroke....or exhaust stroke).
And since the cam isnt in....it hasnt yet been determined.
You can bring #1 to top dead center, and depending on how you put the cam on.....you can make it be so that its on tdc of the exhaust stroke, or tdc of the compression stroke.
Because of the size of the gears....one turn of the crank equals a half turn of the cam. Takes two crank turns to make one cam turn.
When you put it together with number one at TDC, IF you put them dot to dot(crank dot at 12 oclock and cam at 6 oclock), cylinder number one will be at TDC on the exhaust, and number 6 will be at TDC ready to fire.
Its easier to line em up dot do dot.
With one full crank rotation, now both dots will be at 12 oclock, and cylinder #1 will be at TDC on the compression/firing stroke.
My suggestion: Get #1 at top dead center. Instal cam so that cam gear is at 6 oclock(with crank at 1 oclock obviously). It will be easy to see that the cam is dropped in correct with them dot to dot like that.
Then....rotate the crank one full turn leaving both dots at 12 oclock. Now, number 1 is ready to fire and it makes it easier to drop the distributor in and set it for #1 firing.
grumpyvette
grumpyvette
Loc: FLORIDA USA
Reg: 03-16-01
08-05-10 10:04 AM - Post#1956131
    In response to greg_moreira
mightymouse22
Loc: Kelso, WA
Reg: 03-17-09
08-05-10 06:24 PM - Post#1956350
    In response to grumpyvette
much appreciated
85Camaro
Loc: East TN
Reg: 07-14-01
08-08-10 06:11 AM - Post#1957394
With degree whell on crank install a piston stop across the bore. Turn engine one direction until piston contacts stop and mark degree whell with a grease pencil. Turn the other way and do the same. Split the difference and you have TDC.
I made a stop from 2 pieces of flat stock with a nut welded in the middle. just make the gap wide enough for it to allow the correct bolts to bolt it down. I used a brass bolt with a jam nut behind it. In a pinch I have used a flat bar type puller using the pressure bolt as the stop bolt.
Execution time: 0.25 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 10:48 AM
