Username Post: 1950 Chevy Deluxe Fuse Box?        (Topic#245468)
1950Chevyowner
Reg: 07-12-10
07-12-10 10:18 AM - Post#1944231
I have a 1950 Chevy Deluxe that is fully restored. It is all original except pant job. I recently brought it to a body shop to get some paint touched up. It still has the 6 V electoral system in it but the body shop did not know that so they jumped it with a 12 V. Before I brought it to them the radio and clock was working fine. Now it is not. I thought that the body shop may have blown a fuse for them both, but upon looking for a fuse box I did not find one. I checked my 1949-54 Chevy shop manual and it had nothing on a fuse box, also I looked up for a fuse box in parts books and found it. But I still can not find the location of it. So can anyone tell me weather or not does a 1950 Deluxe have a fuse box or not and where can I find it on the car? Also if you know what is wrong with the clock and or radio that would be help too? Thanks
old51sedan
old51sedan
Loc: Michigan & Florida
Reg: 10-11-09
07-12-10 10:49 AM - Post#1944247
    In response to 1950Chevyowner
Look up under the dash to the right of the steering column, there may be an accessory fuse panel installed there. Donn
1951 styleline 2dr deluxe
Original 51 plate, Dealer Tag, Documents
58,000 original miles, second owner
1954 PG 235, rear axle, Power Steering
Fenton Headers With Smitys
stevep
stevep
Loc: San Francisco
Reg: 11-11-05
07-12-10 10:58 AM - Post#1944254
Look for in-line fuses for everything. Electric clock, huh? Most are wind-up.
Steve
'51 Deluxe w/ origional 216 (.060 over), 340k,
6 Volts, 3.55 enclosed rear, Stromberg carb
In the family since 1965
Edited by stevep on 07-12-10 10:59 AM. Reason for edit: No reason given.
1950Chevyowner
Reg: 07-12-10
07-12-10 12:36 PM - Post#1944302
    In response to stevep
Steve you were right about the clock. I forgot that it is a wind-up. As for as the radio, still trying to get it to work.
1950Chevyowner
Reg: 07-12-10
07-12-10 12:37 PM - Post#1944303
Also Donn I looked and it waas not there. But thanks to you both.
super_cheyenne
super_cheyenne
Loc: Williamsport, Pa. USA
Reg: 10-14-01
07-12-10 01:56 PM - Post#1944346
My 1950 styleline deluxe only has in-line fuses that I've found ,up under the dash , in the wiring. Good luck
https://drive.google.com/folderview?id=0BzZQaU uAUs...
Loc: Hendersonville, N.C.
07-12-10 05:33 PM - Post#1944433
There is NO fuse box, guys.
Bob
1951 Styleline Deluxe 2 dr sedan. 1955 235" 3 speed std.
1951 Styleline Deluxe Sport Coupe. 1962 246" 3 speed std. o/d.
canuck
canuck
Loc: Mission, B.C., Canada
Reg: 06-01-02
07-12-10 07:48 PM - Post#1944505
    In response to bobg1951chevy
This is the fuse holder that they sometime used in line with the radio
[image][/image]
A wink is as good as a nod to a blind horse
old51sedan
old51sedan
Reg: 10-11-09
07-13-10 04:45 AM - Post#1944598
Bob is correct there is no fuse panel from the factory and most accessories such as the radio had an inline fuse in it. They made a small acc fuse panel that you mounted on the fire wall under the dash. My car had one put in from the dealer and my radio is wired to it and so is my electric clock. The light for the clock goes to the ignition switch. The fuse panel is shown in the acc. installiation book and you see NOS ones for sale on ebay every once in a while.
2blu52
2blu52
Reg: 03-12-02
07-13-10 04:48 AM - Post#1944601
It is possible to jump a 6V with a 12V but all accessories, lights, must be turned off first. Held on to long the sending unit in the tank will also go. If the radio was turned on it is possibly fried by the 12V. My guess is you will be talking to the body shop about the cost of repair.
THOMAS JEFFERSON
Execution time: 0.271 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 05:13 AM
