Username Post: rear end width?        (Topic#243950)
goatie
Loc: harveys lake, pa.
Reg: 05-22-10
06-16-10 04:54 PM - Post#1931425
I am looking for a modern rear end assy.. I'm pretty sure early Camaros & Novas are compatible. My original rear on my 50 Deluxe is 54 1/2" from backing plate to backing plate. Also, when I find the rear, should I grab the driveshaft too? I want to start gathering parts to convert the whole car to a modern drivetrain eventually. Thanks all!!
'50 Styleline Deluxe
'71 FLH 93" Stroker
'75 XLCH Chopper
'00 Softail
'03 Rottweiler [Bear]
'08 Cane Corso [Fancy]
davidchristopher
davidchristopher
Loc: Saint George, Ontario, Ca...
Reg: 08-02-09
06-16-10 05:34 PM - Post#1931452
    In response to goatie
Goatie-
... search ...
... seriously ....
there must be hundreds of posts about this.
FYI
Rear end: 2nd gen camaro/firebird rear ends are drop in replacements with the exception of having to redrill the locator holes - 1 1/4" forward, 1/8" i (IIRC, YMMV).
Driveshaft: Depends on what trans you use. You'll have to measure.
1951 Chevrolet Styleline Special. (350 4, Powerglide, '55 Driveshaft CE crossmember Heidts Mustang II front suspension, 3:10 Posi)
The '51 Chevy Blog
gsport
gsport
Loc: Salem, Oregon
Reg: 10-04-09
06-16-10 06:46 PM - Post#1931521
    In response to davidchristopher
i just put a S-10 4x4 rearend into my '50.. perfect fit..
Salem, Oregon
1950 chevy, sport coupe. gone, but not forgotten
2011 chevy, SS camaro, synergy green
2011 silverado 4x4 crewcab, 3500 HD
2006 corvette convertible
2014 39ft. 5th wheel
2013 harley fatboy, sold
2006 JD riding mower
50Ragtop
Loc: Tuttle, Oklahoma
Reg: 05-29-09
06-16-10 07:55 PM - Post#1931558
    In response to gsport
Jim, I bought the same rear. Who did you go with for the springs, pads, and shock kit?
Thanks,
Dave
06-16-10 08:14 PM - Post#1931565
    In response to 50Ragtop
I have a 94 4x4 Blazer rear end and I had to move the spring perches out about 3 inches per side and use 1/2 spacers, one of each side, to get the 60 inch width I needed.
gsport
gsport
Loc: Salem, Oregon
Reg: 10-04-09
06-16-10 09:14 PM - Post#1931582
i went with chassisengineering and bought their complete bolt in rear installation kit... about $500.00
Salem, Oregon
goatie
Reg: 05-22-10
06-17-10 02:08 AM - Post#1931605
Thanks guys. Where is the 60" width measurement taken from? What width wheels/tires will this allow to be used & still keep the skirts? Does the 4X4 gear ratio work well with an auto. transor do you plan on changing that?
'71 FLH 93" Stroker
'75 XLCH Chopper
'00 Softail
06-17-10 03:17 AM - Post#1931617
The 60 inches is the stock distance wheel monunting face to wheel mounting face. I had to use the spacers because I had a 55 Chevy rear end and it was 60 inches. So to keep my same wheels and tires I need 60 inches on the 4X4 rear also. The 4x4 rears come is a lot of different ratios. You just have to figure, using engine and tranny, what ratio you want and then look for that. If you do a search on here there are many threads that explain all this in detail and how to find the right rear end ratio.
06-17-10 03:27 AM - Post#1931621
    In response to Bob_Hayden
At the top of this page click "Search" Then "advanced Search" on the left choose 1949 to 1954 Forum, on the right type in the key words, "rear end". Then click on "subject Only" then click "search"
Edited by Bob_Hayden on 06-17-10 03:28 AM. Reason for edit: No reason given.
goatie
Reg: 05-22-10
06-17-10 06:13 AM - Post#1931677
All good info---thanks again. I actually learned how to use the search this morning too! I really appreciate all of the help. Jim
'71 FLH 93" Stroker
'75 XLCH Chopper
'00 Softail
Bill K.b
Loc: upstate NY
Reg: 10-24-05
06-19-10 12:48 AM - Post#1932637
Search here is such a pain in the censored sometimes, there probably aught to be a good sticky on rearend swaps to ID which ones fit and which ones of those bolt in versus which need new spring perches.
I have a '75-ish Camaro rear stored for mine - they darn near bolt in.
Those who can, do. Those who can't, criticize it on the internet.
1988 G20 van 5.7L - driver.
1993 3500 dually 5.7L NV4500 - tow truck
1991 G20 van - parts truck
Plus cars for swap and sale
&yes, I once tried a frame swap on a 51 Chevy.
ralph47
ralph47
Loc: new franklin, ohio
Reg: 10-28-08
06-19-10 04:54 AM - Post#1932692
    In response to Bill K.b
i tried that search on my wife...kept showing to wide
seriously Bob..great way to reduce the search results...everyday i learn something..is a good day..oh crap..wife coming..
i do have several links..as do others here showing rear end widths etc.
54 Chevy Handyman Wagon
48 Chevy Pick Up
39 Chevy Coupe
62 Olds F85 Cutlass Convertible
http://s370.photobucket.com/albums/oo148/ralph47_ p...
gsport
gsport
Loc: Salem, Oregon
Reg: 10-04-09
06-19-10 09:27 AM - Post#1932791
    In response to ralph47
here's alot of good reading, if it comes through.
http://www.chevytrucks.org/tech/ifs&rearend.ht...
Salem, Oregon
super_cheyenne
super_cheyenne
Loc: Williamsport, Pa. USA
Reg: 10-14-01
06-19-10 05:55 PM - Post#1932959
Here's a discusion I saved from a while ago,
http://www.chevytalk.org/threads/showflat.php?Cat=...
https://drive.google.com/folderview?id=0BzZQaU uAUs...
4carbcorvair
Loc: Maine
Reg: 09-02-07
06-22-10 06:18 PM - Post#1934418
    In response to super_cheyenne
Down towards the bottom is a chart for F#$d 9 inch rears. I picked up a 9 inch out of an early Bronco for wifeys project. 4.11's and posi. I'll probalby ditch for highway gears. http://www.maliburacing.com/ford_9_inch/ford_nine _...
Execution time: 0.225 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 09:11 AM
