Join the Community today
Username Post: Bulkhead Connector Terminals        (Topic#239614)
72novaproject
72novaproject
Loc: D/FW Texas
Reg: 02-18-03
04-08-10 09:29 AM - Post#1894960
We have been sort of “fixin up” my sons 1967 ChevyII Nova and the time has come to wire it. We are cleaning up a bunch of electrical gremlins like a poorly designed trunk mounted battery, electric cooling fan, ignition and an electric fuel pump to name a few. We are running a lot of stuff off of relays and we have all of our electrical components established and mounted throughout the car. It is now time to wire it.
I would like to run as much of the control wiring as possible through the factory bulkhead connector as these are low amperage circuits for the relays. Problem is, I cant find these specific terminals. They are NOT the Packard Electric Division “56M” and “56F” terminals I am accustomed to on the 72 Nova or the 70 Chevelle we have in our stable. The bulkhead connectors are in good shape but I need the male and female wire terminals that snap into them. They are smaller than the 56 style and more similar to what I remember (I could be wrong about this) was used in the turn signal switch connector under the dash.
Anyone out there got a source?
Thanks in advance,
Steve
To each problem exists a solution...now think.
The ZD Nova Page
04-08-10 02:46 PM - Post#1895127
    In response to 72novaproject
Steve, are they like the drawing of the "connectors" near the bottom of this page just above "RUBBER SLEEVES"? Click on the part # to get the price, even though it's not blue, it's clickable. Link to connectors.
72novaproject
72novaproject
Loc: D/FW Texas
Reg: 02-18-03
04-09-10 05:15 AM - Post#1895405
    In response to acardon
Thanks Don! That looks like the one but I got lucky and found them elsewhere. These things are a little scarce apparently. They are called a “Packard Twin Lock” and they are not gender specific. The same terminal goes on both sides of the junction block. The last year they were used was in 1967 and after that the 56 style terminals were used. When I started looking for them I found more people trying to find them than I did parts. I found this place on about the 3rd page of a Google search and ordered what I needed from them. Don’t you just love a happy ending!
PCS Performance Connection Systems
Thanks again,
Steve
The ZD Nova Page
TAT_2
"17th Year" Silver Supporting Member, and Official CT Grim Reaper
TAT_2
Loc: "UNDER THE BOARDWALK"
Reg: 10-29-00
04-09-10 05:51 PM - Post#1895833
THINK I GOT A BAG OF EM OUT IN THE SHEAD,I USED EM ON "IH" DASH BOARD CONECTORS
09 PONTIAC- VIBE
08 PONTIAC- G6
96 FURD F-150 SUPER CAB XLT 4X4
NEXT ?
72novaproject
72novaproject
Loc: D/FW Texas
Reg: 02-18-03
04-11-10 06:37 AM - Post#1896629
    In response to TAT_2
I read somewhere in my search that these connectors were very common on commercial agricultural equipment. I assume IH refers to International Harvester.
Steve
The ZD Nova Page
TAT_2
TAT_2
Reg: 10-29-00
04-12-10 05:57 AM - Post#1897133
CORECT
09 PONTIAC- VIBE
08 PONTIAC- G6
NEXT ?
Vaughn
Vaughn
Loc: Colorado Springs, CO
Reg: 08-08-04
04-12-10 09:01 PM - Post#1897641
http://order.waytekwire.com/productdetail2/M50/32 0...
http://order.waytekwire.com/productdetail2/M50/31 0...
These are what came stock on your Chevy II. Yes, I know they say Packard (a lot of connectors from this time period are called "Packard" connectors). These were used universally in late 50 up to early 70s chevy vehicles, including trucks. They click into all bulkhead connectors
Napa also carries these in their "Belden" brand of electrical products.
72novaproject
72novaproject
Loc: D/FW Texas
Reg: 02-18-03
04-13-10 05:03 AM - Post#1897718
    In response to Vaughn
Those are what I expected to find in my son's car Vaughn. But from what I understand and my research shows, is they didn’t start using the Packard Electronic Division (PED) "56" Style terminals you linked to until after 1967. Or not in the bulkhead connector anyway. The 67 Nova, or at least my son's came with the ones shown below. Here's the info from the place I bought them.
18/20 gauge Packard Twin Lock Terminal 2973915
Price: $0.75
25 In Stock
Item Number: 2973915
Manufacturer: Delphi
Manufacturer Part No: 2973915
Female Delphi Twin Lock Tin Plated Terminal
Outside Cable Diameter (including Insulation) 2.89 - 2.05
Cable Range mm2 0.80 - 0.50
Typically used as a bulkhead terminal on 1960's GM and Dodge Chrysler, Plymouth vehicles
Delphi Packard # 2973915
The ZD Nova Page
Vaughn
Vaughn
Reg: 08-08-04
04-13-10 09:06 PM - Post#1898196
I have those Packard terminals in several vehicles, including two 66 pickups that I have rewired. I have replaced them in a number of 67-72 pickups also (I have gone through several boxes of them since the early 1990s on wiring jobs) - so I know that they were used both prior to 1967 and afterwords. I've used them on a few early 60s cars also.
I can't tell you why they aren't working on your Chevy II, unless some previous owner did some rewiring on your bulkhead connectors, and used something different.
04-14-10 07:16 AM - Post#1898329
My '66 Corvair uses the twin-lock connectors in the engine compartment connector as well as some of the under dash connectors.
72novaproject
72novaproject
Loc: D/FW Texas
Reg: 02-18-03
04-16-10 01:19 PM - Post#1899645
I should have plenty left over if you need some Don. Just let me know and I will run them out to you. I had to buy a special crimper ($98.00 Ouch!) and you can borrow that too.
Steve
The ZD Nova Page
Edited by 72novaproject on 04-16-10 01:21 PM. Reason for edit: No reason given.
GeerHed
Loc: Lincoln Ne
Reg: 06-17-10
06-17-10 02:26 PM - Post#1931850
I saw your posting. I am currently reworking the wiring on our 73 Camaro and found these links that have several sources for the Packard 56 terminal and connectors as well as Mopar and Ford stuff. some have a minimum of 50 but at $0.17 each its cheaper than buyin 5 at the price some of these guys want.Hope it helps.
http://www.rowand.net/shop/Tech/AutomotiveE lectric...
Also
http://www.usmracer.com/Connectors-Terminals_ c_197...
72novaproject
72novaproject
Loc: D/FW Texas
Reg: 02-18-03
06-18-10 05:34 AM - Post#1932148
    In response to GeerHed
Thanks GeerHed,
It was the "Packard Twin Lock" terminals I had a hard time finding but I have plenty now.
Thanks for the links! I am always looking for a place to get this stuff and after wiring the ChevyII I need to re-stock my electrical cabinet for the next job.
Steve
The ZD Nova Page
lovebohn
lovebohn
Loc: Central Wisconsin
Reg: 08-27-13
10-10-17 01:21 PM - Post#2710428
  • 72novaproject Said:
Thanks GeerHed,
Steve
Yes super old post but would you or anyone else have some of the twin locks? I can't find them and the ones on Mouser look to be the smaller 18-20 ga ones and I need a 12 if I can find it. Thanks.
Execution time: 0.205 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 03:37 AM
