Username Post: 2-piece driveshaft angles        (Topic#239436)
629C1 Impala
Reg: 04-04-10
04-05-10 07:43 PM - Post#1893586
Hi, I'm brand new here so please bear with me....
I've read and been told that it is best to treat the front shaft as if it is an extension of the tail housing therefore aligning it almost straight (1/2 degree) with the engine and trans.
Then to set up the rear shaft as if it was a one piece shaft.
Problem I'm experiencing is a slight shudder on take off. Harder I push the pedal the worse it is. I'd have to look at my notes but I believe I have all three right close to 1.5 now.
Car is a 62 Impala with a 4L60e so front shaft is shorter and rear has a complete adjustable 4-link which also made the rear shaft shorter.
Ideas??
Thanks!
doubleE
doubleE
Loc: Eagan MN
Reg: 06-02-03
04-06-10 04:24 AM - Post#1893691
    In response to 629C1 Impala
Angle at the tailshaft does not need to be stright but should be the same angle as at the rear end.
One thing to check is the u-joint "phasing". A search on here should come up many hits on this subject.
Eric
Lynn63
Lynn63
Loc: Vicksburg, MI
Reg: 02-07-09
04-06-10 09:11 PM - Post#1894153
    In response to doubleE
Eric, you are dead on with the phasing issue. I took my driveshaft in to be shortened after I installed a 200-4R in my 63 and the shop person noticed the front shaft was "out-of-phase" (or so he thought). Not knowing I told him to do what he felt necessary so he put it "in-phase" and I developed a pretty bad vibration. After reading a post about phasing on CT I took it back to him, along with the page from the assembly manual and he fixed it. Vibration was gone after that.
Lynn
Lynn63
63 Impala SS
07 Silverado DMax Classic
99 Venture van
Progress so far...
629C1 Impala
Reg: 04-04-10
04-06-10 10:05 PM - Post#1894169
    In response to Lynn63
The phasing is correct and the balancing has been done by the best....
Somebody in this "X-Frame" group surely must have dealt with the angles of these driveshafts??
bborc
Loc: MI
Reg: 02-03-06
04-07-10 03:51 AM - Post#1894223
Hi 629c1. I had the same problem on my 62 impala. The shop manual shows how to set the angles if you have one if not do a search on here or google two peice drive shaft. I had that same chutter when first taking off and ended up Installing one of thoses polyurathane center bearings from inland driveshaft. I also had the driveshaft place put in a slip joint in the rear shaft. No more problems after that.If you need more info contact me at my e mail address in my profile
Edited by bborc on 04-07-10 04:09 AM. Reason for edit: No reason given.
bowtieollie
bowtieollie
Reg: 12-06-99
04-07-10 04:20 AM - Post#1894231
Hi 629,
Do a search on this topic within the 58-64 forums.
The topic has been addressed perfectly.
No sense in me rehashing the topic....
Bowtieollie
Chevytalk.com Moderator
629C1 Impala
Reg: 04-04-10
04-07-10 09:04 AM - Post#1894358
    In response to bowtieollie
Thanks to both of you!!
61ragtop
Loc: Langley B.C. Canada
Reg: 07-30-03
04-08-10 06:42 AM - Post#1894827
bowtieollie
bowtieollie
Reg: 12-06-99
04-08-10 02:23 PM - Post#1895084
    In response to 61ragtop
Hi 61,
Thank you very much for posting the link to that topic....
Bowtieollie
61ragtop
Reg: 07-30-03
04-09-10 06:25 AM - Post#1895416
No problem I have it saved in my fav links. I still have not gotten mine to the proper specs but no vibe or shudder here. It is also very modified suspension and WAY lower than stock too though.
629C1 Impala
Reg: 04-04-10
04-09-10 11:55 PM - Post#1895961
Bowtieollie, Thanks, I read all the past posts but I still have a nagging question...........
Since the front shaft does not move up or down why not just deal with the center and pinon angles of the rear shaft as if it were a one piece like any one piece shaft vehicle???
Granted you would need to put a slight,1/4-1/2, angle on the front angle to keep the needles rolling.
Help me understand why this isn't possible...
Thank you again!1
turbo38s10
turbo38s10
Loc: Agawam,MA
Reg: 09-17-09
04-10-10 02:02 PM - Post#1896259
Go to the manuals section above. Open it and then open the 1961 Chevy Shop manual, open the rear axle section. About half way thru you see everuthing your asking , pictures and explanations as well as how to.
bowtieollie
bowtieollie
Reg: 12-06-99
04-11-10 07:00 AM - Post#1896606
Hi there,
Actually, the front shaft does move up and down!
If you put a video camera under the car, you may be shocked at how that engine/transmission bounces around merrily down the roadway....
I once had a GM Engineering video done for Hydramatic durability testing. The mule was a 1970 Buick Skylark 455. Hood was removed and cameras were installed under the car. Now get this... the "test driver" held his foot to the floor and shifted between D and R as the car rolled within a 20-30 foot section of concrete.
You should see the dynamics with the driveline and of course with the hood off - you could see that BEAUTIFUL Quadrajet WOT and the 455 at full song... and these guys got paid to do this....
Just remember to keep the front U joint angle the same as the rear. I always start at the front first - then measure the rear.
Bowtieollie
Edited by bowtieollie on 04-11-10 07:02 AM. Reason for edit: No reason given.
Execution time: 0.312 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 03:55 PM
