Username Post: Finding #1 spark plug on distributor cap        (Topic#237759)
ttowka
Reg: 05-30-09
03-14-10 12:46 PM - Post#1879958
I think when changing cap i messed up firin order. I know 18436572 is the order but which one on the cap is #1
350 smallblock 1980 k-20 4x4
fritz1990
fritz1990
Loc: Kansas
Reg: 02-16-03
03-14-10 12:50 PM - Post#1879960
    In response to ttowka
This one right here, I know it's a BBC, still the same.
Regards, Jeff
1998 K1500 6.5 Coal burner
1965 C10 with 498 BBC AFR Heads
1964 C10 Ran 348W for 6 years, now SBC.
Corvettes owned: '74 '77 '78 L82 Silver Anniversary, 2002 LS1
Don't have a nervous come together!
http://picasaweb.google.com/fritz199090
ttowka
Reg: 05-30-09
03-14-10 12:57 PM - Post#1879965
    In response to fritz1990
thank you so much never thought someone would download pic. Helps alot
fritz1990
fritz1990
Loc: Kansas
Reg: 02-16-03
03-14-10 01:02 PM - Post#1879969
You're
It has been asked a few times and pics are easier than typin'.
Glad to help!
Regards, Jeff
ttowka
Reg: 05-30-09
03-14-10 01:04 PM - Post#1879973
hmmm not sure but 18436572 starting from there didnt work made it worse
Petroholic
Petroholic
Loc: Moses Lake, Wa.
Reg: 08-12-05
03-14-10 01:15 PM - Post#1879980
Just set your motor at TDC and where the rotor is pointing is #1. ..am I right?
ttowka
Reg: 05-30-09
03-14-10 01:40 PM - Post#1879992
    In response to Petroholic
im by my self so gettin TDC is problem till i can get help ...... Fritz are u sure about the pic
ttowka
Reg: 05-30-09
03-14-10 01:51 PM - Post#1879997
could it be because when i changed cap and rotor i didnt replace little peace under coil inside of cap
Has a little spring on it
Distributor BUTTON thats what it is
Edited by ttowka on 03-14-10 02:07 PM. Reason for edit: found what parts called
ttowka
Reg: 05-30-09
03-14-10 02:25 PM - Post#1880008
Its gettin dark guess im done for the day (plus im gettin mad feel like setting truck on fire)
If anyone has any info that can help let me know
Ill check the site later thanks
DEI8FAN
DEI8FAN
Loc: Western, N. Carolina
Reg: 02-01-05
03-14-10 02:37 PM - Post#1880014
pull number 1 plug (the front on drivers side) have someone bump the key for you or use a starter button. hold your finger in the plug hole until the compression blows your finger off. Line the mark on the balancer to the tap at top dead center and look where the rotor is pointing. that will be number 1 compression stroke. If you had the distributor out or someone else did it may not have lined up on the oil pump shaft. aka it may be off. the rotor moves clockwise.
1959 El Camino
1970 El Camino
1981 Corvette
2004 Z71
2005 Monte Carlo
Edited by DEI8FAN on 03-14-10 02:39 PM. Reason for edit: No reason given.
Anonymous
03-14-10 02:52 PM - Post#1880021
Try this picture of my distributor. It shows a little more of a closeup:
The plug wire that is off is #1. Check its orientation to the Vacuum advance can and the distributor cap mounting screws.
ttowka
Reg: 05-30-09
03-14-10 02:53 PM - Post#1880022
    In response to DEI8FAN
I didnt remove the distributor so should still be right. im try the finger/screwdriver in piston timing trick tomorrow but my Q still is do i need to go get the button (that i lost) i had to put the old one in
ttowka
Reg: 05-30-09
03-14-10 02:56 PM - Post#1880024
    In response to Bobs85PU
thanks thats 2 people that have said its at front right so my order is correct
DEI8FAN
DEI8FAN
Reg: 02-01-05
03-14-10 03:34 PM - Post#1880048
Well drivers side is the left but I was in parts so I used to ask driver or passenger?
1959 El Camino
1970 El Camino
1981 Corvette
2004 Z71
2005 Monte Carlo
fritz1990
fritz1990
Loc: Kansas
Reg: 02-16-03
03-14-10 03:45 PM - Post#1880059
Same place as my pic. This is where the factory puts #1. If the dist has been out per PO they may not have put #1 there. Only way to know is find tdc and align rotor with Factory #1.
Regards, Jeff
fritz1990
fritz1990
Loc: Kansas
Reg: 02-16-03
03-14-10 03:51 PM - Post#1880063
You should be able to use the old rubber gasket, spring, and button from the old one if it isn't burnt.
Regards, Jeff
Anonymous
03-14-10 04:48 PM - Post#1880085
Hey Jeff, I hope you don't think I was tying to upstage you...I just thought a closeup Pic would help...
C10 Sleeper
C10 Sleeper
Loc: Redding Ca
Reg: 03-17-09
03-14-10 05:47 PM - Post#1880111
Just to keep things easy so I don't have to think too hard. Any time I pull the plug wires or distributor I will set my timing mark on the balancer to 0 and check to make sure the rotor is pointing towards the number 1 spark plug hole before I do anything. As long as I don't have to turn the motor it keeps things on the really easy side and if it takes me a few days to get everything back together I don't have any problems
I do everything with out any helpers so it just keeps everything simple so I can focus more on why I had to do what ever I am doing.
http://photobucket.com/C10Pictures
fritz1990
fritz1990
Loc: Kansas
Reg: 02-16-03
03-14-10 05:50 PM - Post#1880113
No, not at all Bob. I thought that he might have been or was going to be confused. That was a way better pic than I had anyways.
Regards, Jeff
Anonymous
03-14-10 07:35 PM - Post#1880177
Regards, Jeff
A while back, I bought a Digital Camera that has Macro capability...works great for taking closeup pics!!
fritz1990
fritz1990
Loc: Kansas
Reg: 02-16-03
03-14-10 07:49 PM - Post#1880186
Mine has macro too, just that I didn't need it for that pic I took 4 years ago. It's the only one I had that I knew showed what I wanted to show. Then I had to take it into paint to scribble.
Like I have said before, I am no good at conveyin' my thoughts to finger words.
Regards, Jeff
Edited by fritz1990 on 03-14-10 07:50 PM. Reason for edit: No reason given.
dbradley
dbradley
Loc: Sapulpa, OK
Reg: 11-15-09
03-14-10 08:14 PM - Post#1880196
http://www.hotrodders.com/forum/attachment.php?att...
Dave Bradley
62 Belair 496 TKO600
33 3W Master Coupe
06 C6 coupe 6spd
Anonymous
03-14-10 08:18 PM - Post#1880197
Jeff, as a 15 year Technical Writer, I learned one thing...a picture is worth a million words!!!
I could spend X amount of time and X number of words, explaining how to properly refer to left/right in regard to describing locations on a vehicle...but a picture with a few words works better!!! And if one keeps in mind, all components are referred to in the same way...the front of the engine, is to the front...the left side of a distributor, is to the left...
ttowka, this is for your future reference...
Anonymous
03-14-10 08:23 PM - Post#1880200
    In response to dbradley
  • dbradley Said:
Another very good example of a picture/drawing saving a million words!!!
ttowka
Reg: 05-30-09
03-15-10 03:41 PM - Post#1880584
Ok good news bad news
Good news my timings on or atleast within a 1/8 turn of distributor And thank to yalls help i know the plug wires are in the right spot
Bad news i tried crankin it and it sound like it was popin thru carb (after pourin gas in carb because i changed my fuel filter and if you run that truck out of gas it needs a shot or 2. Same as changing fuel filter lines empty). Ok now im checkin other stuff besides timin issue. I found when i took off fuel line and cranked it no fuel at all cam thru and iv run the battery bout dead twice messin with timing. and it ran before i park it and replaced Cap and rotor and coil
So my Q is: It gettin no gas and me pouring gas in cause pops thru carb
And Vaughn told me in other post Check for proper fuel supply to carb and i didnt stupid
Little more info at http://www.chevytalk.org/fusionbb/showtopic.php?ti...
Edited by ttowka on 03-15-10 03:49 PM. Reason for edit: No reason given.
Anonymous
03-15-10 05:40 PM - Post#1880685
To ensure I understand everything...this problem didn't rear its ugly head until you replaced the distributor cap, but then reinstalled an old (possibly bad) part (the distributor rotor, or is it the spring loaded button in the middle of the distributor cap)...correct?
If you are back firing through the carburetor, that means (electrically) one of two or three things...
1. Your timing is too far advanced...but, as you haven't moved the distributor, we can eliminate that as a possibility!
2. You've reinstalled the spark plug wires starting at the location of #1 cylinder Jeff and I indicated in our pictures...and, you installed them in the correct direction (clockwise looking down at the distributor cap) as dbradley showed in this illustration:
And are you sure, you traced every plug wire to verify each wire is in it's proper position in the distributor cap
3. You reinstalled a bad part (the old part).
The best advise I can give you, is two fold:
1. Recheck every wires position...verify that you are positive every wire is going to the correct spark plug...in the proper direction (clockwise).
2. Replace the old part...which I assume is the rotor...and if it's the button from the middle of the distributor cap, I'd go buy a new cap, and start over.
Something else I just thought of...and I almost did this to my engine, twice in the last year...be damn sure you have the distributor rotor indexed correctly...the rotor can be installed 180 degrees out if you don't watch what your doing, and "force it back on"..
There are two small "pegs" on the bottom of the rotor...it is possible, but not probable, you could have done that.
The other thing I thought of, was do you have the distributor cap securely on the body of the distributor...and all lock tabs are in place...use your fingers to ensure the tabs are between the "tits" at all locations on the distributor body.
Impalaman1966
Loc: Yorkville, Il., USA
Reg: 03-17-01
03-16-10 03:22 PM - Post#1881167
Be aware that you can put Number One terminal anywhere on the distributor. Most of us make sure the rotor points to the number one cylinder, just to make things easier in the future. Someone once upon a time may have done yours differently.
And do what Bob said to do.
uk ss
uk ss
Loc: south coast uk
Reg: 02-13-08
03-17-10 02:55 AM - Post#1881441
    In response to Impalaman1966
Shot in the dark..........Did you change the rotor arm and put it on backwards? Difficult i know but my wife managed to do it!!
dumb a ss brit!!
88 Silverado
http://s272.photobucket.com/albums/jj162/jamiedud e...
dbradley
dbradley
Loc: Sapulpa, OK
Reg: 11-15-09
03-17-10 06:12 PM - Post#1881865
    In response to uk ss
The old square peg in the round hole thing..........
Dave Bradley
33 3W Master Coupe
06 C6 coupe 6spd
Anonymous
03-17-10 06:20 PM - Post#1881874
You got it...with a good quality rotor, I don't think (I know, there I go thinking!!), you could reverse the rotor...With some of the junk plastic parts available now days, It's a real possibility.
Execution time: 2.427 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 01:07 AM
