Username Post: Roller cam valve adjustment        (Topic#237151)
Senior Chevytalk Moderator
03-06-10 07:02 PM - Post#1875209
I need to adjust my ZZ4 valve lash. How different is the procedure from hydraulic lifters? Do rollers hydraulic lifters need a tighter lash?
The rockers are stock 1.5 ratio. How wide should I set the valve lash?
Why do I need adjustments? I drive it like I stole it.
fritz1990
fritz1990
Loc: Kansas
Reg: 02-16-03
03-06-10 07:28 PM - Post#1875225
Not 100% sure on Hyd Rollers but think it would be the same as a Hyd FT cam, around 1/2 turn past zero.
Regards, Jeff
1998 K1500 6.5 Coal burner
1965 C10 with 498 BBC AFR Heads
1964 C10 Ran 348W for 6 years, now SBC.
Corvettes owned: '74 '77 '78 L82 Silver Anniversary, 2002 LS1
Don't have a nervous come together!
http://picasaweb.google.com/fritz199090
Petroholic
Petroholic
Loc: Moses Lake, Wa.
Reg: 08-12-05
03-06-10 07:37 PM - Post#1875235
    In response to fritz1990
Not to highjack you G, but I've heard anywhere from 1/4 turn to 3/4 turn past 0 lash on flat tappet cams.
Which is correct?
fritz1990
fritz1990
Loc: Kansas
Reg: 02-16-03
03-06-10 07:41 PM - Post#1875240
    In response to Petroholic
I have always ran mine at no more than 1/2 turn. This has been working for me for a few years.
Regards, Jeff
Edited by fritz1990 on 03-06-10 07:41 PM. Reason for edit: No reason given.
Pistol
Pistol
Loc: Terryville, Ct.
Reg: 11-11-02
03-07-10 05:54 AM - Post#1875391
I emailed Comp Cams about that a while back because it use to say on their spec sheet to adjust tappets to zero lash, so I ran my new motor like that for a short time and the tappets were making noise, so that's when I emailed them with questions, they have changed all of their spec sheets from what I can tell to just say Hyd and they said 1/4 to 1/2 turn after zero
Pete
Awl speeling misteaks r myn
57 BelAir 2DRHT My-Pics
03-07-10 04:14 PM - Post#1875768
    In response to Pistol
Pistol
I agree. I did some research on the ZZ4. Factory lash is zero. I'll set them all to zero. I guess over time the lash increased or nuts came loose. The zero lash should quiet down the valve train a little. Currently it's louder than the exhaust! The metal valve covers echo sound! I need Vette valve covers.
aghaga
aghaga
Loc: Altavista, Va.
Reg: 07-05-08
03-07-10 06:32 PM - Post#1875861
In essance when you adjust a hyd. to any preload it is running at zero lash. That may be what their thoughts are.
Anonymous
03-07-10 07:18 PM - Post#1875895
I'd just do what I learned 50 years ago. Zero lash, then 1/4 to 1/2 turn...but fill the lifters with oil before starting the engine...a can full of oil, and a spare pushrod with a handle attached...PUMP ME UP!!!
Submerse the lifters in the can of oil, then push up and down, on the lifters, one at a time till they hydraulic lock...
That's what I'm planning when I change the cam in my Vortec, roller cam engine!
fritz1990
fritz1990
Loc: Kansas
Reg: 02-16-03
03-07-10 07:29 PM - Post#1875903
    In response to Bobs85PU
I gotta agree that you should have some preload on the lifters. At least a 1/4 no more than 1/2 turn.
I just dove into a 5.3 a week ago and the lifters are non adjustable but I could see the lifter plunger compress when I tighten the rockers. They are Hyd. Rollers.
Regards, Jeff
Edited by fritz1990 on 03-07-10 07:31 PM. Reason for edit: No reason given.
Petroholic
Petroholic
Reg: 08-12-05
03-07-10 07:48 PM - Post#1875913
I've got little experience building engine, but all of what I'm reading says not to soak lifters.
Maybe someone else can chime in here.
fritz1990
fritz1990
Loc: Kansas
Reg: 02-16-03
03-07-10 07:52 PM - Post#1875916
I have never soaked Hyd lifters before install. I have built a few over the years.
Regards, Jeff
03-07-10 08:04 PM - Post#1875925
Hydraulic lifters spin in their bore. Roller hydraulic lifters don't spin in their bore.
C10 Sleeper
C10 Sleeper
Loc: Redding Ca
Reg: 03-17-09
03-08-10 01:23 PM - Post#1876301
I have never soaked my lifters in oil I usually set mine at 1/4 turn past 0 lash while installing them then do them while the motor is running and just tighten them until they stop clacking. I have an old tall valve cover with a slot cut out the length of the top of the cover just wide enough to get a socket onto the nuts. I can adjust my valves while the motor is running and not make a mess doing it.
http://photobucket.com/C10Pictures
Execution time: 0.254 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 09:25 AM
