Username Post: Bolt Size for Shocks        (Topic#235527)
mwright1
Loc: Naperville, IL
Reg: 04-05-04
02-12-10 01:59 PM - Post#1861444
Just picked up a set of Bilstein shocks and going to put them in this weekend, but need to know the size of the upper and lower bolts? Also not sure about the size of the smaller nut on the top of the front shocks. I'm assuming I'll need a long socket for that one. Its for a 2003 4x4 silverado
I'm soaking them with some PB Blaster now in hopes they come off easy.
Edited by mwright1 on 02-12-10 02:00 PM. Reason for edit: No reason given.
black95jimmy
black95jimmy
Loc: Venice, FL
Reg: 01-05-02
02-12-10 02:50 PM - Post#1861480
    In response to mwright1
You will have to cut the top ones.
82 Monte Carlo SC, 355 w/Vortec heads, roller rockers, 670 Street Avenger, TRUE DUALS.
2009 Sub.5.3L LTZ 30 Gallons of gas @ $2.49/gal. bla bla bla.
mwright1
Loc: Naperville, IL
Reg: 04-05-04
02-12-10 03:37 PM - Post#1861510
    In response to black95jimmy
Thanks, but what exactly do you mean by cut the top ones? Cut them off with a hacksaw?
If it ain't broke open it up and make it better 03 Silverado 5.3 Z71
black95jimmy
black95jimmy
Loc: Venice, FL
Reg: 01-05-02
02-12-10 03:47 PM - Post#1861522
Abrasive wheel is better, or a Nut Cracker, those top ones always rust on.
http://www.google.com/products/catalog?sour ce=ig&a...
mwright1
Loc: Naperville, IL
Reg: 04-05-04
02-12-10 03:57 PM - Post#1861529
Good info.. Thanks.. do you know the bolt size for the rears and lower front?
black95jimmy
black95jimmy
Loc: Venice, FL
Reg: 01-05-02
02-12-10 05:04 PM - Post#1861574
No, can't help there.
andykirk
Loc: NC
Reg: 12-15-05
02-12-10 07:01 PM - Post#1861681
MWRIGHT1 that's scarey !! I just got my Bilstein shocks today for my 2003 4x4 silverado too and was planing on putting them on until this snow started here in NC !! I got mine from a place in TN that had a website and you can call as well. It's called Top Gun Customz. I got the 5100 series which are the silver with black boot for $268 plus $19 shipping. I turned up my torsion bars on the front so I needed the ones for the 2" lift. What style did you get? I am waiting to see how my ride improves. Current ones are shot. Andy
mwright1
Loc: Naperville, IL
Reg: 04-05-04
02-12-10 09:15 PM - Post#1861756
    In response to andykirk
Wow, that is freaky...I got the stock replacements. Got them from eshocks, on-line for $255 with free shipping. Honestly they are ugly looking, yellow with blue boot, but didn't really have a choice. Hopeing to get them on this weekend. My stock ones are shot also, only have 55K miles. Hope to notice some improvement. Still trying to figure out the bolt size to get them off, look like 22 or 23 MM but not sure.
BBC-454
BBC-454
Loc: Edmonton, Alberta
Reg: 05-11-03
02-12-10 10:41 PM - Post#1861800
I live in an area where they salt the roads 6months of the year and have only had a few out of many that I had to cut off due to corrosion.
The upper shock nut is 15mm, I use a gear wrench but a normal one will work, you also need an 8mm to hold the shaft from spinning, or a large pair of pliers. lower bolt is 21mm or 18mm, same with the nut.
Rears are 21mm top and bottom.
Front shock lower bolt is 18mm on 1500's, 21mm on 2500/3500's if I remember correct.
Josh R.L.
Licensed Automotive Mechanic
1966 Buick Special 2 door
1961 Chevrolet Apache 10 panel van
1995 GMC K2500
2011 VW Jetta TDI
Edited by BBC-454 on 02-12-10 10:42 PM. Reason for edit: No reason given.
andykirk
Loc: NC
Reg: 12-15-05
02-14-10 01:14 PM - Post#1862677
Hey Man, I put my bilsteins on today. If you have not done yours yet call me. I got some tips for you. Andy 336-284-6418
black95jimmy
black95jimmy
Loc: Venice, FL
Reg: 01-05-02
02-14-10 01:42 PM - Post#1862689
We have a PRIVATE TOPIC area, DON'T put your phone number here.
mwright1
Loc: Naperville, IL
Reg: 04-05-04
02-14-10 01:43 PM - Post#1862690
Just put mine on this morning too. Went pretty easy.. Soaked the bolts overnight they all came off fairly easy... New ones went right on. Only noticed a little difference so far.
Rears and bottom front bolts were 21 mm. Front top is 15mm for the stock shocks, and 17 mm for bilstein replacements.
andykirk
Loc: NC
Reg: 12-15-05
02-14-10 02:56 PM - Post#1862747
Yep, I was looking for a button to send a private msg. Where is it ? Thanks, Andy
mwright1
Loc: Naperville, IL
Reg: 04-05-04
02-16-10 11:42 AM - Post#1863907
Got mine on with out any major problems, but just curious what were your tips? My only tip is to watch your head on the bottom edge of the fender corner just behind the rear wheel. Ask me how I know.
andykirk
Loc: NC
Reg: 12-15-05
02-17-10 06:50 PM - Post#1864811
I was able to put an open end wrench on the welded nut that is on top of the front shock just below the frame mount. Then I put a deepwell impact socket on from the top and got them right out. Andy
aero48
Loc: Il
Reg: 01-14-05
02-27-10 03:42 PM - Post#1870611
I ordered KYB shocks for my '03 Z-71 4 days ago. Just rotated the tires and decided I needed shocks.After cleaning up the hubs and rims I sprayed all of the shock bolts with GIBBS penetrant. I will spray them again before
attempting the change after reading this topic.
Thanks!
2003 Z71 5.3 Standard cab
mwright1
Loc: Naperville, IL
Reg: 04-05-04
02-27-10 08:18 PM - Post#1870755
    In response to aero48
I sprayed all mine the day before and didn't have any problems getting them off. I used a pair of vice grips to hold the front ones with a deep socket to get the nut off that worked pretty well.
Execution time: 0.501 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 03:48 PM
