Username Post: '64 3/4 Ton rear end gears        (Topic#235019)
cactusbud
cactusbud
Loc: Kansas City
Reg: 04-11-08
02-05-10 12:13 PM - Post#1856953
Hello all, Quick question about the rear end gears for a '64 C20 with coil spring rear end. My understanding is that this is an Eaton unit(Has round rear cover and removable 3rd member) and was told it was a HO52 and am looking at local vendors for Ring and Pinion Sets in 3.55 or 3.73. So far, I have had no luck as everyone is telling me they are NA. Can anyone tell me if this info is correct for this rear end and if there is a vendor who has ring and pinion sets for my truck. Thanks, Bud
1966 C10 Shortbed Fleetside w/ Big Window
455 Olds Rocket/ M-20 trans
1965 C20 LWB Beater "Ranch Truck"
250 L-6 SM-420
1956 GMC 350 Series Grain Truck
316 Pontiac V-8 SM-420
http://www.flickr.com/photos/66511554@N00/
bobschevytrucks.com Ecklers
LGriffin
Loc: Gateway to Yosemite
Reg: 04-16-04
02-05-10 05:41 PM - Post#1857116
    In response to cactusbud
All the information you've given is correct. The best you are going to be able to do is 4.10. IIRC you'll find these gears in Suburbans with automatics up to 1972. I believe the HO72 third member will swap into the HO52, but there maybe an issue with axle splines. If I'm wrong we will hear about it. 8^)
Larry
I don't own a vehicle that isn't old enough to drink.
christopherlutz
Loc: Flower Mound, Texas
Reg: 11-10-06
02-06-10 04:02 PM - Post#1857585
    In response to LGriffin
There is a vendor - I'll check and get back to you - unfortunately, your only gear choices on this full floater are:
4:56 (stock)
4:10
I have a 65 C20 - swapped the rear end for a 69 12 bolt.
Lutzy
1965 C20 (completely dismantled)
2008 Chevy Silverado 1500 (5.3l V8)
2006 Honda Pilot EX
cactusbud
cactusbud
Loc: Kansas City
Reg: 04-11-08
02-06-10 04:26 PM - Post#1857604
    In response to christopherlutz
I think that 4.10 gears would be a definite improvement in drive ability over the 4.56 gears, i will be anxious to hear back, Thanks to both, Andrew
250 L-6 SM-420
LGriffin
Reg: 04-16-04
02-06-10 06:22 PM - Post#1857645
Hate to disappoint you, but I wouldn't get excited about 4.10 over 4.56. The reason I say that is that I went from 4.56 to 3.73 in 68 C20 with a sm465. That allowed me to get out of the intersection with second gear, before I was shifting to third before the crosswalks. I would still like to have 3.30 to 3.55 gears, so I could be under 2500 RPM at 65 mph.
Find an RPM calculator and run some numbers. I think you'd find that larger tires might make the difference between 4.56 and 4.10. I went with an OD in my 63 C20 that bumped my mpg from 12 to 16, and dropped my RPM from about 3300 to 2500.
Larry
Edited by LGriffin on 02-06-10 06:32 PM. Reason for edit: No reason given.
Vaughn
Vaughn
Loc: Colorado Springs, CO
Reg: 08-08-04
02-06-10 08:24 PM - Post#1857720
The last known supplier that I know of was Patrick's trucks, who had a number of 3.73 gears made up for the Eaton axle that came stock in 47-72 3/4 ton trucks (the HO52 axle). The 1 ton axle was the HO72 eaton, which was similar (had larger axleshafts, apparently).
http://www.patricksantiquecars.com/index.htm
They aren't giving the gears away, in case you were wondering. Expect prices above $750, and a fair amount for professional setup (which you HAVE TO HAVE).
You would be MUCH better off swapping a later 14 bolt single axle rear in, you can get examples for $200-300 in the 3.73 range. They are a bit of a squeeze to get under a 64, but you can do it with wheels that have a bit more offset than stock.
hilandr451
hilandr451
Loc: Anna Texas
Reg: 01-02-02
02-07-10 11:36 AM - Post#1857976
    In response to Vaughn
Larry,
what size tires did you end up going with to achieve that kind of performance?
I also have an Eaton from a '64 donor truck in my '66. I am hoping that my buddy's '66 C20 with a factory powerglyde has a 4:10 in it. He's converting to 1/2 ton running gear for tires & rim selection and I've got dibs on the diff.
I am currently running a 1991-ish 5.7L V8 in front of a TH700R4.
-The Hilander.
Silver 2017 Silverado 1500 double cab 2WD 5.3L
"Rattle can primer red" 1966 C20 Custom Camper 5.7L, 700 R4 trans 410 diff. front disc, p/s
Project Pics
persh
persh
Loc: Tucson, Arizona
Reg: 07-19-00
02-07-10 03:55 PM - Post#1858099
    In response to hilandr451
I ended up with a Dana 60 axle (I had the mounting pads removed and redone for the coil spring setup) and put 3.52 gears in it. With 235/85-16 tires (350/700R4) it cruises down the freeway very nicely and gets away from stop lights with plenty of zest......
'60-'66 Idea Page or Corvair Stuff
Edited by persh on 02-07-10 03:55 PM. Reason for edit: No reason given.
LGriffin
Reg: 04-16-04
02-08-10 08:01 AM - Post#1858438
  • hilandr451 Said:
Larry,
The tire size is 235/75 16, but I didn't change tire size, I changed transmissions. I pulled the sm420 and replaced it with NP A833(RPO MY6). The A833 has a 26% overdrive for fourth.
Larry
ccpanel
Loc: nor-cal
Reg: 04-05-09
12-29-10 11:28 PM - Post#2024319
I know old post but there is another option-late 60's vans used the HO72 and commonly came with 3.73 gears.
Im told also that the internals are virtually identical to the later model 14 bolt axles.(not verified)
gear calculator;
http://www.grimmjeeper.com/gears.html
http://customclassics.org
Suppose you were an idiot. And suppose you were a member of Congress. But I repeat myself.
- Mark Twain
MKline
MKline
Loc: Pawnee, Oklahoma
Reg: 08-17-06
12-30-10 12:05 AM - Post#2024324
    In response to ccpanel
I know these are out there... 'cause I found one. Some 67-72 C20s and GMC 2500s with coil spring rears have Dana 60 differentials. I am having mine worked up with 3.54 gears and a positrac. I was probably lucky to find mine... Good Luck!
1966 K20 Flatbed
LGriffin
Reg: 04-16-04
12-30-10 09:48 AM - Post#2024441
    In response to MKline
There was also a rumor that 3.90 gears were available for the Eaton HO differentials. A couple of Stovebolters researched 3.90 gears, and many have looked for them, not to be found. This is the first I've heard of 3.73 gears.
The Eaton HO diffs and the GM 14 bolt do share some parts albeit it's a one way swap. IIRC you put the HO carrier in a 14 bolt, but the reverse is not true.
Larry
kieth
Loc: Tulsa, Oklahoma
Reg: 08-05-10
12-30-10 10:07 AM - Post#2024450
Give these guys a call they are knowledgable
Axles, Transmission, and transfers 918-425-7725 ask for richard he knows and has some older units. Kieth
Vaughn
Vaughn
Reg: 08-08-04
12-30-10 02:31 PM - Post#2024552
    In response to kieth
The parts in the Eaton HO axles are not interchangeable with the later 14 bolts. The only similarities that they share is that they will nearly bolt in place of each other.
There was a place that used to have Eaton gears, and they used to advertise on the Stovebolt site. I believe it was Patricks, but am not sure since it has been a while. They weren't giving those gearsets away either - they were charging upwards of $800 for the privilege of supplying people that gearset - and because of that price most people just swapped in a different rear with more reasonable gears and posi availability.
Execution time: 0.234 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 08:18 AM
