Username Post: 92 Blazer Digital Dash        (Topic#234974)
edmchevys10
edmchevys10
Loc: Alberta , CANADA
Reg: 07-08-03
02-04-10 06:00 PM - Post#1856563
hello, my 1992 s10 Blazer has the digital speedometer and gauges, recently the gauges have been flickering and turning off on me frequently, I have a 91 s10 blazer parts vehicle with the anolog gauges in it, can I just swap over to the old style gauges? or will it not match up? thanks
92 GMC S15 Jimmy 4 Door 2WD 4.3 Vin Z
250.000 KMS
GMBOB
Loc: WARREN,MI,USA
Reg: 01-31-01
02-05-10 03:25 AM - Post#1856748
    In response to edmchevys10
It will not swap out easily. The I/P harness is different. The turn signal flashers and 4 way flashers are in different locations, and the connector on the cluster is different.
31 Chevy 5-Wdo Coupe
55 Chevy
55 Chevy 3200 V8 Hydramatic
56 Corvette
29 Chevy 2-DR Sedan
86 GMC Crew Cab (500,000+ miles)
90 GMC Suburban
Senior Chevytalk Moderator
02-05-10 07:15 AM - Post#1856807
    In response to GMBOB
You should be able to adapt it with a wiring diagram. It will take a little bit of work. I suggest looking for a simliar replacement.
Choaf
Choaf
Loc: Oklahoma
Reg: 11-03-04
02-07-10 12:45 PM - Post#1858015
There are people that will repair the dash for you on ebay but you would need to know if its bad solder joints or the power supply going bad.
I have also heard you can just wire in your connector from the parts truck to the original wires and then your analog cluster would work. The wires are all the same color so should be simple enough. I think I read a few wires arent in the analog plug but they are mearly power cables for the digital dash so wont be needed once you rewire. but I am no expert on this just some information I have read in other sites.
In god we trust, all others must pay cash.
91 S-10 4wd 4dr Blazer: 4.3
98 Yukon 4wd 4dr: 5.7
57 Bel-air 4dr sedan: 283 w/powerglide
38 2dr Olds business coupe: 455
Execution time: 0.288 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 03:02 AM
