Username Post: Put it out a broken Heater Hose Connector SUBURBAN `99        (Topic#233571)
crisman
crisman
Loc: México City
Reg: 03-12-07
01-15-10 08:33 AM - Post#1842754
Hi guys I usually post in the 1949-1954 forum but now I need your advice.
I have a 1999 suburban and yesterday i was looking for a colling leak and when i move the heater hose I found the problem because the heater hose connector broke And now my problem is that the screw part of heater connector is in the intake manifloid I spray a lot of DW40 on it an use an extractor tool and try to rotate out but its too tight; can someone have any advise to take out the broken heater hose connector??? I dont want to hurt the intake using bruting force jejeje
crisman
EN ESTA VIDA HAY QUE SER AMIGO DE DIOS Y DEL DIABLO >:p
black95jimmy
black95jimmy
Loc: Venice, FL
Reg: 01-05-02
01-15-10 09:14 AM - Post#1842779
    In response to crisman
Depending on the pipe size, I have used a hack saw blade and cut the old pipe long ways in two places and then took a chisel or screw driver and knocked it out.
careful with the cuttings though!
82 Monte Carlo SC, 355 w/Vortec heads, roller rockers, 670 Street Avenger, TRUE DUALS.
2009 Sub.5.3L LTZ 30 Gallons of gas @ $2.49/gal. bla bla bla.
2plus2
Loc: Mission,BC
Reg: 02-03-05
01-15-10 09:48 AM - Post#1842796
    In response to black95jimmy
what he said
if you can get a small blade in there and cut just enough out before you get into the threads and then hit it with a hammer and pointy object you should be able to collapse it in and it will come right out
69 Canadian Pontiac 2+2
rcr3
rcr3
Loc: Manheim Pa. U.S.A.
Reg: 11-24-02
01-15-10 11:22 AM - Post#1842832
If you go to a dealer ask for part# 24503681 that's a steel replacement,shouldn't have that problem again.That's all we use here at the GMC dealership.
'12 Cruze RS LTZ
'73 Nova hatchback Sold 12/23/12
'37 Chevy cp.SOLD!!6/7/14
'74 Nova Custom cp.
'73 Nova pro-street project
'17 Chevy Trax LT
'00 S10 Ex cab
'06 Z71 Sierra Ex Cab
'67 Camaro survivor
crisman
crisman
Loc: México City
Reg: 03-12-07
01-17-10 06:41 PM - Post#1844180
    In response to rcr3
Heyyy guysss thanks for the help, today with more DW40 and the extractor tool i can be able to take out the broken part
But never ends jejejee now the water pump is leaking so in this week Im going to change it,,, any thing to worry about the replacement or trick on the unbolt of the old waterpump.
crisman
black95jimmy
black95jimmy
Loc: Venice, FL
Reg: 01-05-02
01-18-10 05:25 AM - Post#1844351
Glad you have it out.
01-18-10 05:36 AM - Post#1844353
Just did the water pump on a friend's '95 Suburban. Pretty straightforward. Just take off the belt, drain coolant, unbolt the fan and disconnect the hoses and it should just be the 4 bolts into the block. They are a little bit buried with the rest of the accessories still in place, so be careful getting the first two bolts started. I used Permatex blue on the gaskets. It is ready to assemble immediately. I put a bolt through each side and guided the pump into place and started the bolts a few turns by hand and put in the other bolts and tightened in a criss cross pattern.
Execution time: 2.306 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 01:12 AM
