Username Post: Adjust transmission Cable (Shifter Cable)        (Topic#230549)
bobby9621
Loc: Midwest
Reg: 06-30-08
11-27-09 06:23 PM - Post#1813661
I am attempting to finish my transmission job, I'm excited because I am done, and can't get the darn cable synced up. Happy I am almost done but freaking pissed. Anyways I tried following the directions, but the dang thing won’t seem to sync. If anyone has some step by step instructions an idiot could follow this would really help.
96 Chevy K1500 ext cab z71 short bed, with a 4L60E.
Thanks,
Bobby
1996 Chevy Ext. Cab Z71 5.7 Liter
"You've already spent your two cents and I don't accept credit..."
Edited by bobby9621 on 11-27-09 06:41 PM. Reason for edit: No reason given.
11-27-09 06:25 PM - Post#1813663
    In response to bobby9621
What cable?
bobby9621
Loc: Midwest
Reg: 06-30-08
11-27-09 06:26 PM - Post#1813665
    In response to someotherguy
Transmission cable, goes from your shifter to your tranny. I am not able to get it synced up, another words park is park, neutral is neutral etc...
11-27-09 06:30 PM - Post#1813668
Ah, OK. Shifter cable.
The adjustment is down at the transmission end. There's a little clip that goes in that holds the assembly together; you'll see it has a row of teeth. You're supposed to be able to squeeze the retainer and adjust the cable, but I'll be honest with you, my one or two attempts at this didn't work out too well. Once the cable is old, those plastic parts get pretty brittle.
bobby9621
Loc: Midwest
Reg: 06-30-08
11-27-09 06:33 PM - Post#1813675
I can adjust it, however I am unable to sync it up. I thought u started in neutral at both sides and then tighten. But when I run the gears through they are off.
11-27-09 06:52 PM - Post#1813685
I would go for adjusting in park, not neutral. The column has an upper limit of how far it will let the shifter travel, which should also be the limit of the travel on the cable toward the stud it snaps on at the transmission.
bobby9621
Loc: Midwest
Reg: 06-30-08
11-27-09 09:53 PM - Post#1813776
I adjusted in park, and I can get all the gears, however it does not always want to go back into park. I think it may be time for a new cable, but not sure how to tell.
Execution time: 0.25 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 05:08 AM
