Username Post: Longest-lasting car battery?        (Topic#230316)
knightfan2691
knightfan2691
Loc: Elgin IL
Reg: 11-18-02
11-23-09 11:18 PM - Post#1811375
The last Sunday of August (August 30, 2009), I had to buy a new battery for my 1981 Monte Carlo SC. I've owned this car since December 1999 (when I bought it from my parents) and have not previously replaced the battery during my time as owner. The old battery was a GM/AC Delco battery.
So ... I asked Dad to look through his records to find out when that battery was installed. He looked and found that it was bought and installed February 4, 1997. The '81 MC SC had 167,000 miles at that time. When I replaced that battery, the car had 192,000 miles.
Thus ... that GM/AC Delco battery lasted over 12.5 years ... and 25,000 miles.
What is the longest a battery has lasted in your car(s)?
Cort | 36swm.IL | "Mr Monte Carlo"."Mr Road Trip" | pig valve.pacemaker ...radio show, Dec 09
WRMNshowcase.legos.HO.models.MCs.RTs.CHD = http://www.chevyasylum.com/cort
"Nothing lasts forever" ... Guns N Roses ... 'November Rain'
Algoma56
Reg: 03-14-05
11-27-09 12:30 PM - Post#1813453
    In response to knightfan2691
I had a 88 Chev sportside, with the original Delco battery in it. I wasn't original owner, but knew the battery was OEM. I finally rpelaced it around '01. Sounds like close to the same time you got.
HAL_396
HAL_396
Loc: Austin, TX
Reg: 11-16-06
12-08-09 01:40 PM - Post#1820244
I have been buying Optima batteries until I realized the same thing you did. Those Delco batetries seem to last for-ever. I just bought a new one last week for my newest build. Cost about $92.00 out the door. They are hard to find. Only a couple places had them in a city of 130,000.
Its funny because I don't think there are many battery manufactures. So one company should make several brands of batteries. Why Delco seems to last longer just befuddles me.
1955 Chevy Custom
1966 Biscayne
1966 Caprice Drag Car Inwork
1966 Caprice parts car
Thurman55
Loc: Albany,Ga. Gold Member
Reg: 05-23-02
12-14-09 05:27 PM - Post#1824057
    In response to HAL_396
"Hal_396", I see your post is dated 12-08-09, so I'll try to give a little insight. I worked for GM/Delco-Remy in a plant making alternators. For some reason, we were told "internal politics" the plant was closed after twenty years of making monies and having a reputation of high-quality. I was then transferred to a Delco-Remy battery plant, which later closed after the auto industry went ka-pooty. I can safely say that IF you are looking for one of those older, original type "Delco" batteries, you are out-of-luck in today's world. To the best of my knowledge--Delco-Remy/Del co/Delphi stopped making batteries in the U.S. about May of 2008 when all of Delphi(s) (at the time) battery business was sold to Johnson Control, which had been one of our main competitors. JC did not keep any Delphi plants, just shifted customer contracts over to their plants. As far as how Delphi batteries were made--I can explain this to you if you have about a week to listen. The only other battery which I have seen the inside of was an EXIDE battery when they started making the "spiral cell" technology and we acquired some of these to cut open to learn how they did this. I do know that the car batteries we built in the plant I was in had thick, very thick, plates, which may attest to their longevity. I retired from that plant in Jan. '05, then the bankruptcy, and nothing's been just fine since. Thanks, David
x inFEKTid x
x inFEKTid x
Loc: east side of atl
Reg: 04-14-08
12-14-09 09:59 PM - Post#1824253
    In response to Thurman55
optima batts dont last more than a year for me . i have a red,blue, and yellow top all lasted about a year -year and a half at the most
HAL_396
HAL_396
Loc: Austin, TX
Reg: 11-16-06
12-15-09 11:08 AM - Post#1824470
Thank you for the insight about Delco Batteries. I'm glad I bought one while they are still available.
So what brand of batteries does Johnson Control make? Does anyone make a battery as good as the Delco's?
1955 Chevy Custom
1966 Biscayne
HAL_396
HAL_396
Loc: Austin, TX
Reg: 11-16-06
12-15-09 11:12 AM - Post#1824472
    In response to x inFEKTid x
I've had one in my 55 chevy now for about 5 years. Has never failed me. When not in use I always put it on a battery maintainer. Maybe that's the trick. Or maybe they are making them different now than they use to.
1955 Chevy Custom
1966 Biscayne
Vaughn
Vaughn
Loc: Colorado Springs, CO
Reg: 08-08-04
12-15-09 05:32 PM - Post#1824668
It's REALLY important that you don't the cook the optima style battery - a bad alternator (with a bad diode or the voltage regulator set too high) will cook them, and if you use the wrong style of battery charger you will cook them.
They can stand a FEW deep discharges, but if you discharge/deep discharge them on a regular basis (like when someone wires the field of the alternator to the output wire, to "fix" an alternator problem) they won't last very long.
Anonymous
12-15-09 07:46 PM - Post#1824782
    In response to Vaughn
I put an Optima in my Son's VW when I built it...it lasted 10+ years. Then my Daughter bought him a security system/car alarm...the battery started giving him problems.
We replaced the battery...same problem...removed the damn alarm system, never a problem again.
I truly believe that battery would still be in the car 15+ years later, if I'd read a story about the Optima batteries earlier.
Turns out, if you deep discharge them, you can't simply recharge them like a "normal" battery. You have to be patient, and slow charge them for a few days, then put them on a regular charge.
At the local CO-OP here in Hitchcock USA, I noticed that one of the Farmers had traded in an Optima cause he couldn't get it to hold a charge.
I asked the manager if I could take it home...he said, "sure, it's no good!"
That battery has been working fine for over three years now...I did as the article said, I charged it on a trickle charge for a few days, then charged it "normally" for a day...it has never failed to start and run any vehicle I've put it in.
And its never lost its charge!!!
I now use it to run a fuel transfer rig I set up for when we have a loss of power here in rural OK...Winter time normal thing. This way, I can move fuel from undriven vehicles to my generator.
fritz1990
fritz1990
Loc: Kansas
Reg: 02-16-03
12-15-09 08:43 PM - Post#1824815
    In response to Bobs85PU
I have been running the Gates batteries, now called Optimas, since they came out years ago. I run diesels only for daily transportation for the last 25+ years and these are the only batteries that I will put in them.
Only failure was a mistake on my part, left an accessory light on and didn't catch it for a few days and drained a pair of 'em, which has been stated is a Other than that I average at least 5 years a set. My last set I changed a couple months ago was 8 1/2 years old.
Regards, Jeff
1998 K1500 6.5 Coal burner
1965 C10 with 498 BBC AFR Heads
1964 C10 Ran 348W for 6 years, now SBC.
Corvettes owned: '74 '77 '78 L82 Silver Anniversary, 2002 LS1
Don't have a nervous come together!
http://picasaweb.google.com/fritz199090
Anonymous
12-15-09 08:55 PM - Post#1824818
    In response to fritz1990
Regards, Jeff
Like I said in my post, if you had the opportunity to trickle charge them for a couple of days, then "normally" charged them, you'd probably still be using them!!!
As in your case, and my case, too much knowledge too late!!!!
bowtieollie
bowtieollie
Reg: 12-06-99
12-16-09 04:31 AM - Post#1824888
JC is making just about everyone's batteries.
Ranging from Interstate to Walmart to Advance Auto to Sears.
Keep in mind, that Exide also makes batteries for private labels.
So my point is if you buy a new battery, it is going to be either a JC or Exide battery.
The JC batteries are mfg'd just as well as the Delco's were.
In regards to a Delco living for over 10 years - that is rather impressive and certainly not the norm. If you get 4-5 years out of it - I would consider anything more to be "borrowed time".
Heat is the single biggest killer of batteries, so expect shorter battery life in those areas that get hot.
As a matter of preventive maintenance, I toss my JC battery (with Delco label) every 4.5 years.
Its cheaper than a tow truck.....
Bowtieollie
Chevytalk.com Moderator
HAL_396
HAL_396
Loc: Austin, TX
Reg: 11-16-06
12-17-09 11:01 AM - Post#1825666
    In response to bowtieollie
I certainly agree with the heat. My 09 Pontiac G5 has the battery in the trunk in the spare tire well. I can't believe the Mfg's finally figured out the benefits of putting a batter back there.
My 04 trucks battery is still fine after a little over 5 years but I live where it is cold 9 months out of the year but I keep my garage heated at 55 when it does get cold. I'd like to see batteries last 7 yrs. under these conditions.
1955 Chevy Custom
1966 Biscayne
01-18-10 08:04 PM - Post#1844890
Johnson Controls has made Sears Die Hard batteries for just about forever. I think they also make Interstate batteries. Somebody correct me if I don't have that right.
I think Johnson and Exide are are only mfr's left for traditional wet cell batteries. They are all made by one of the two if it's a US sold automotive wet cell battery.
I had several AC-Delcos start leaking battery acid through the side terminals. Seems like that happened rather than the usual sulphating/shorted cells.
My last battery death was when my 2009 GMC had its battery give up the ghost at 3 months/3000 miles. I wasn't impressed. I was even less impressed that it was just 600 or so CCA. And the most CCA I could buy (quickly) for a replacement was just 700 CCA.
1956cpe
1956cpe
Loc: Carlsbad, CA
Reg: 07-07-04
01-20-10 09:44 PM - Post#1846286
    In response to Rick_L
I've had a red top Optima for at least 5 years now. If the car is going to sit for a month I'll use the dis-connect switch. It has not failed yet. As in other forums on this topic, I have to say that opinions are directly related to personal experience. Mine, along with other people that I know, give Optima a thumbs up.
pete
01-21-10 08:55 AM - Post#1846422
    In response to 1956cpe
I wish I'd had my Optima long enough to form an opinion. It was one of the many things stripped off my '92 when it was stolen!
If I had the extra bucks to lay out I'd buy another, but before that I've got a whole pallet full of maybe-good / maybe-bad batteries here to choose from before I exhaust all my options.
rod
Loc: kingman,az
Reg: 04-29-00
01-29-10 03:25 PM - Post#1852299
    In response to someotherguy
exide used to make sears die hard batteries. back in the 70's and 80's. they would leak acid out the terminals. the president of exide knew about this problem, however to fix it would have cost him a very large amount of $. so they just keep on making faulty ones. after while, people, like me, complained about the acid eating up the tray and generally not lasting. then there was a law suit filed against exide. the president got fired and exide lost contracts with sears and some other private label co's. it has taken exide years to overcome the problem. personally i would never use a sears or exide battery ever.
this is America, stand up for your product, and you will have a following.
rod
cbernhardt
cbernhardt
Loc: Lexington,NC
Reg: 08-28-00
01-30-10 05:31 AM - Post#1852693
I had the OEM Delco battery in my '98 Corvette fail after three years. The positive battery terminal separated from the case spilling acid on the frame and some of the plastic wrap on the wiring harness, a real mess. Luckily the computer, which is located in the area under the battery, was not damaged. One of the old timers at the Chevy dealer told me that this side post separation was a problem with the OEM batteries on a lot of GM cars, but the replacement Delco's did not seem to have it.
Charles
01-30-10 01:33 PM - Post#1852927
    In response to cbernhardt
All the ones I had a problem with were replacement batteries purchased at the auto supply. For a while I stuck with them - I'd trade in the leaker for a new one and pay the pro-rate, but finally enough was enough. They would last 18-30 months, just like other batteries. Difference was the leaked rather than be sulfated or have a dead cell.
ratnfested
ratnfested
Loc: Rochester, NY. USA
Reg: 03-13-00
02-23-10 10:16 AM - Post#1867949
My 86 Grand Prix got a new battery in 94 right after I painted it and got the new motor running. I park the car all winter with the battery disconnected but sitting in the car and the battery just finally quit in the fall of 2008. And it gave no warning. That was a Champion battery. Now owned by Exide.
Philip Ferrera
1977 Chevelle
1977 Malibu Classic
1986 Grand Prix
1995 Tahoe
2003 Impala LS
2004 Ski Doo REV
Street Machines of Rochester NY
HAL_396
HAL_396
Loc: Austin, TX
Reg: 11-16-06
02-23-10 12:02 PM - Post#1868019
    In response to ratnfested
8 years sounds about right for a quality battery. I hope I hope I get that out of all my delco batteries.
1955 Chevy Custom
1966 Biscayne
sidworks
Loc: Sidney, B.C.
Reg: 12-03-05
02-25-10 02:07 PM - Post#1869377
I got 11 years out of an interstate in my 64 that was used for cranking a detroit all those years
ron
http://www.sawmillcreek.org/showthread.php?208929-...
http://www.sawmillcreek.org/showthread.php?220902-...
http://forum.woodenboat.com/showthread.php?156542-...
hilandr451
hilandr451
Loc: Anna Texas
Reg: 01-02-02
06-25-10 07:43 AM - Post#1935769
    In response to tam85
  • tam85 Said:
car batteries are very important to operate our vehicle. the most popular car battery brands are champion, napa, exide, diehard, duralast, interstate motorcraft and everstart. i prefer duralast. got one from auto parts online.
Of all those brands on the market, I wonder how many of those batteries are actually made by the same manufacturer?
p.s.: hi ron!
-The Hilander.
Silver 2017 Silverado 1500 double cab 2WD 5.3L
"Rattle can primer red" 1966 C20 Custom Camper 5.7L, 700 R4 trans 410 diff. front disc, p/s
Project Pics
HAL_396
HAL_396
Loc: Austin, TX
Reg: 11-16-06
06-25-10 01:29 PM - Post#1935942
    In response to hilandr451
Well my Delco battery in my 04 truck died a couple weeks ago. It didn't make it 6 years.. I replaced it with a NAPA 84 month battery.
1955 Chevy Custom
1966 Biscayne
Edited by HAL_396 on 06-25-10 01:30 PM. Reason for edit: No reason given.
brad_bb
brad_bb
Loc: Joliet, IL.
Reg: 07-13-01
07-20-10 03:41 PM - Post#1948377
I'm an Optima guy myself. I heard of some people with Optima trouble years ago, but my experience has always been good. It's not impossible that the batteries have gone through design changes and refinements. This would not be unusual. My 55 Chevy, which doesn't see much use I must admit has had it's OPtima for 6 years. My Saturn daily driver for 8 years. My 91 Chevy pick up for 6 years, and my 55 ford Tractor has had an Optima 6V for 3 years now. No issues with any so far. My 55 chev and ford tractor are kept on the Battery Tender when not in use. It's important not to leave them discharge for long storage, or they will likely be unrecoverable.
If someone else can design it, I sure as heck can figure out how to fix it!
HAL_396
HAL_396
Loc: Austin, TX
Reg: 11-16-06
07-20-10 06:04 PM - Post#1948437
    In response to brad_bb
I forgot to put the tender on my Optima a few weeks ago and it drained down to about 8 1/2 volts. I was able to save it by charging it using the 1.5 amp tender. No problems since.
1955 Chevy Custom
1966 Biscayne
knightfan2691
knightfan2691
Loc: Elgin IL
Reg: 11-18-02
07-21-10 08:43 PM - Post#1949081
Your experience mirrors what I've heard ... trouble years ago, but most-recently, nothing but good things....
Cort | 36.m.IL | 5 Monte Carlos.1 Caprice Classic | pig valve.pacemaker * 07/24/2010=ChitownMeet #3 *
MCs.CC | models.HO.legos.CHD.RadioShows | RoadTrips.us66 = http://www.chevyasylum.com/cort
"This can't be the end" ... Bertie Higgins ... 'Key Largo'
Vaughn
Vaughn
Reg: 08-08-04
07-22-10 07:31 PM - Post#1949553
Optima batteries and other spiral cell batteries had trouble with certain types of battery chargers, like the early versions of AutoMeter Battery Extender that use modified AC square wave to eliminate sulfation in lead acid batteries. The ac signals sent out by the battery charger tended to short out the AGM mats separating the lead plates, causing battery failure.
Apparently their new circuitry eliminates this, although I personally won't use my Battery Extender on any of my Optima batteries.
The battery tender style of charger is a float charger, so doesn't have that same effect on the Optimas.
Execution time: 0.282 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 12:00 AM
