Username Post: More air in brake lines!!        (Topic#228256)
BG
Reg: 09-12-07
10-23-09 07:16 AM - Post#1792991
I have had poor brakes on my 1990 Chevy 1/2 ton pick up and replaced the rubber lines this week, bench bled the master again to see if this would help. After bleeding the front they seem to be ok, and the rear had some air at first but I finally get solid fluid but when I go check the fluid in the reservoir (I never let it get too low) I put the lid back on, then go back to the old style bleeding where someone pumps the brakes while I open the bleeder and when I open the bleeder I get a big burst of air, I re-bleed them to solid fluid and then check the reservoir and once again I get a burst of air. I have gotten these results every time. I do not see how this can be connected but I can not get the rear brakes to bleed correctly. The brake pedal is never released before I tighten the bleeder valve! There are no leaks in the system that I can find and I have no fluid loss.
Jim.Biron
Jim.Biron
Loc: Monterey, TN
Reg: 04-10-08
10-23-09 10:26 AM - Post#1793091
    In response to BG
The rule (As I always understood it) was to bleed the brake fatherest away from the MC first and then work your way forward toward the MC.
www.HudsonValleyCruise.com
BG
Reg: 09-12-07
10-23-09 11:03 AM - Post#1793116
    In response to Jim.Biron
The way I bleed them is to start at the right rear, the left rear then move to the right front then the left front. I am still getting air at the rear.
Vaughn
Vaughn
Loc: Colorado Springs, CO
Reg: 08-08-04
10-23-09 12:37 PM - Post#1793167
    In response to BG
Your master cylinder could be bad. If the internal seals are damaged, air could be getting by the rear seal - making brake bleeding impossible.
Get a good AC Delco master cylinder from Napa. Up to 50 percent of other parts stores master cylinders fail right off the shelf.
52chevybob
Reg: 05-27-08
10-23-09 02:01 PM - Post#1793203
    In response to Vaughn
Could be that you don't understand how to bleed.
The process is to apply pressure to the brake peda, open the vlave for a bit, letting whatever escape and then close the valve before the pedal gets to the floor. Seal the valve and recycle to the pedal high and pressure position and reopen the valve. Check the MC to make sure that it doesn't get too low or you will be putting air back in again.
BG
Reg: 09-12-07
10-23-09 05:37 PM - Post#1793330
    In response to 52chevybob
I have bled the brakes on different vehicles in the past without a problem but this one does have me questioning if I am doing something wrong. I am not doing anything different from when I have bled other brakes. I am wondering if the master cylinder has a leak as mentioned in the above posting.
tjn.
Loc: louisville, kentucky usa
Reg: 02-16-05
10-23-09 05:41 PM - Post#1793332
    In response to BG
BG, Sit in the car with the ignition off, hold your foot firmly on the brake pedal and see if the pedal drops. If it does drop and you don't find any leaks you're in the new MC business. TJN
BG
Reg: 09-12-07
10-23-09 06:01 PM - Post#1793349
    In response to tjn.
tjn,
I just went out to my truck and tried the pedal and it will go down about half way then it holds. Earlier I was trying to bleed them again with a vacuum pump and all I could get was air out of the rear. I tried to gravity bleed them but I could hardly get a drop at a time. I do have better brakes backing up! The brake pedal does not return like I think it should, could this be part of the problem?
tjn.
Reg: 02-16-05
10-23-09 07:35 PM - Post#1793401
    In response to BG
BG, don't know, but it sounds like the MC is o'kay or it would have let the pedal sink. TJN
wheelman
wheelman
Loc: Long Island--New York
Reg: 04-14-07
10-23-09 07:51 PM - Post#1793408
    In response to tjn.
How's the proportioning valve?Any leaks?
1968 Impala Sports Coupe
2004 Jeep Grand Cherokee
Save a Classic - Crush an Import
[url=https://www.facebook.com/greg.leonovich [/url]
BG
Reg: 09-12-07
10-23-09 08:07 PM - Post#1793421
    In response to wheelman
There are no leaks and I just took out the proportioning valve because I was having trouble getting it to reset and swapped it with a used one that is supposed to be good but I am still having trouble getting the air out of the system. I have tried gravity, pressure on the pedal and vacuum to bleed these and have been thru 1and 1/2 gallons of fluid. I have bled brakes on different vehicles over the years and never had this kind of trouble.I am thinking of getting a pressure tank and trying it.
BG
Reg: 09-12-07
10-23-09 08:22 PM - Post#1793427
    In response to BG
My brake pedal does not return like it should and I need to check this out. Could this be keeping the piston in the master cylinder out of the correct position and causing the problem with bleeding the brakes? This may just be a problem under the dash and nothing to do with the brake bleeding problems.
N8sToolz
N8sToolz
Loc: N 42° 53.290' W71° 34.1...
Reg: 10-23-03
10-24-09 12:45 PM - Post#1793693
    In response to BG
Fluid starts at the master, so you really have to start there. The pedal not comming back up is def a sign that something is not right.
My guess would have been higher on that number, forever getting bad ones. I have not used the AC delco ones though.
Does the rear of the truck have a load valve? It adjusts the rear line pressure depending how much weight is in the back of the truck. If it does I would delete it from the system.
BG
Reg: 09-12-07
10-24-09 03:06 PM - Post#1793747
    In response to N8sToolz
From what I can tell the truck does not have a valve for weight, it does have the combination valve without ABS. While using the pedal to apply pressure while bleeding the brakes the pedal would not come all the way back up so I would lift it the final inch or so but right now to check the pedal it seems ok.
Vaughn
Vaughn
Reg: 08-08-04
10-24-09 10:04 PM - Post#1793936
    In response to BG
I've run into a lot of different brake problems over the years - and almost every time a brake system can't be bled via normal brake bleeding procedure, the master cylinder is the culprit.
Master Cylinders - even the high quality parts store units - are not that expensive. If nothing else, you insure that your master cylinder won't need to be looked at or changed out for the next 10 years or so.
BG
Reg: 09-12-07
10-25-09 11:35 AM - Post#1794145
I plugged the ports on the master and it holds pressure. I did find what looks like a leak at the right rear wheel cylinder so I am going to replace both of those. Since the brakes have always been on the weak side can I change out the calipers or wheel cylinders to a different size to get more brakes??
tjn.
Reg: 02-16-05
10-25-09 02:42 PM - Post#1794226
    In response to BG
BG, if you change out the calipers to "larger" then the rotors have to also change to "larger". Never heard of stouter/stronger wheel cylinders.
BTW, I readjusted my rear (disk) brakes so that the inner pads just contact the rotors and it made a marginal improvement in the pedal "drop". TJN
52chevybob
Reg: 05-27-08
10-25-09 03:53 PM - Post#1794265
    In response to tjn.
Generally wheel cylinders also need to change the backing plate as the backing plate sets the offset of the cylinder from the backing plate. Putting larger cylinders on there will make the cylinder push the shoes at an angle. It is also uusal to have the bolts at different locations from one size to another.
I'd suspect thaat calipers also have the same problem with differences between the rails.
The only real way to get stoonger brakes is to build a higher pressure in the system.
BG
Reg: 09-12-07
10-25-09 07:01 PM - Post#1794387
I was just hoping there was a way to upgrade the brakes. Today I replaced the rear cylinders and while I had it apart I disconnected the rear line from the combination valve just to see if I could draw fluid thru the line with the small mighty vac hand pump and I could not draw the fluid thru the line, I reconnected the lines and used speed bleeder valves that have the check valve built in and was able to bleed the rear lines but the brakes are still bad even after this. The master cylinder checks out ok but there is something not right with these brakes.
64Bel Air
Reg: 07-08-09
10-27-09 04:47 PM - Post#1795380
    In response to BG
You have remember there is many different styles of brake systems. And not all brake systems can be bled from the farthest from the master first. So please look up your style of brakes very carefuly. Also Master cylenders will hold preasure to lines even when your not on the pedal or anything so air in the master be prepared to reblead the master off the booster or off the car completely. Best bet, Draw on a peice of paper exactly how your brakes are run. Find out the style, and buy a power bleeader and ALWAYS check the master level
Edited by 64Bel Air on 10-27-09 04:50 PM. Reason for edit: No reason given.
Execution time: 0.468 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 03:53 PM
