Username Post: rear shock mount replacement        (Topic#227318)
cedgo
Reg: 10-07-09
10-07-09 04:05 AM - Post#1784380
Hi everybody! Rear shock mounts rusted away. Is there a source for bolt on replacements or other solution? 1994 K1500 Silverado.
scrambldcj8
Loc: MA
Reg: 04-06-03
10-07-09 04:42 AM - Post#1784393
    In response to cedgo
weld them on....or have someone weld them on for you. I am sure any shop with a welder would do it for a modest fee.....? beer.
http://diy4x.com/cart/index.php?route=product/prod...
cedgo
Reg: 10-07-09
10-07-09 04:51 AM - Post#1784397
    In response to scrambldcj8
Thanks for reply, Im a little slow on shocks. Have a welder. Been looking on the net and can't seem to find any mounts. Where should I look?
355Cheyenne
355Cheyenne
Loc: Northern MN
Reg: 10-27-04
10-07-09 04:52 AM - Post#1784400
scram provided a link to the shock mount that is on the axle side. which side rusted off, at the frame or on the axle?
98 Silverado k1500 4x4 350
cedgo
Reg: 10-07-09
10-07-09 05:12 AM - Post#1784406
    In response to 355Cheyenne
Great, I was wondering what all those digits were. Will check out the link he provided. Both mounts are rusted off at the frame. Very little metal left. Thank you.
cedgo
Reg: 10-07-09
10-07-09 05:36 AM - Post#1784416
Just checked the link, but couldn't see what I needed. I would think that with all the 4WDers and all the 1500 trucks out there that someone, somewhere would have a solution to this problem. This can't be the only truck to have the mounts rusted off.
cedgo
Reg: 10-07-09
10-08-09 07:52 AM - Post#1785071
OK. Been all over the web and can't find much of anything specifically for the truck. Did find a "shock relocation kit" and a "rear shock bar kit". Has anybody had any experience with either?
controlfreak
controlfreak
Reg: 05-19-04
07-07-10 05:42 AM - Post#1941733
junkyard.
stumppuller
stumppuller
Loc: Canada
Reg: 11-01-04
07-08-10 06:23 PM - Post#1942622
    In response to controlfreak
Those are riveted on, and can be replaced using Grade 8 hardware. The junkyard would be the cheapest route, but the dealer should be able to get them, but they may be pricey (www.compnine.com shows them for $112 each).
-91 Sierra C2500, now K2500
-81 Chev K20
MustGoFaster
MustGoFaster
Loc: Oregon
Reg: 11-28-03
07-09-10 03:26 PM - Post#1943057
    In response to stumppuller
if you can't find them in a junk yard, just find something that 'works'. as long as they are in 'about' the same location, anything will work.
91 K1500 EC/SWB, 322k original miles
79 Jeep Cherokee Chief, off-road toy
07 Mazdaspeed3, bolted track rat
Execution time: 0.234 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 11:42 PM
